Old 11-06-2015, 10:16 AM   #1
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Screech when starting
Hey guys -
Occasionally when I start my '07 hatchback, I get a grinding sound for a fraction of a second after the car starts. Happens mainly on the first, cold start of the day and then doesn't typically happen again. Not always, but happening more lately. Link to video below. Your thoughts are appreciated.
https://youtu.be/gSGKUFNL0kE
Old 11-06-2015, 10:44 AM   #2
NEexpat
Drives: 2009, auto, 4dr LB
I'm just guessing here but have you checked serpentine belt?
It could be time for a new one.
NEexpat is offline   Reply With Quote
Old 11-06-2015, 11:17 AM   #3
Ya, it's the belt. A more successful search would include the word 'squeal'.
Old 11-06-2015, 01:29 PM   #4
ern-diz
ern-diz's Avatar
Thanks for the replies.
Would the serpentine belt make a similar squeal sound as most belts do when they get old? The sound I'm hearing is not that higher pitch squeal you typically hear from a bad belt. It's much more of a crunching screech. Like I said, if you've ever not realized a car was running and turned the key, it sounds more like that. A crunchy screech, more than a higher pitch squeal.
If it is the belt, could it have gotten bad/dry just from the 8 yrs of exposure? I ask because the car only has 62k miles on it.
Old 11-06-2015, 01:38 PM   #5
Yes. Like any rubber product, time does deteriorate them. It may also be just fine, but needs to have the tension adjusted, but I'm betting on age.
Type of sound aside, which can be subjective when it comes to describing it, the timing of the offending sound does indicate that the serpentine is the source.
Old 11-06-2015, 01:57 PM   #6
ern-diz
ern-diz's Avatar
Gotcha. Thanks again for the info.
Is it something you would trust a good local mechanic with looking at, or should I have Toyota take a look at it on my next service appt.?
Old 11-10-2015, 06:22 PM   #7
ern-diz
ern-diz's Avatar
Got a video of it.
If you turn the volume up, you can hear it right as the car starts up. Really short, abrasive sound. Not the typical, high pitch squeal you get with bad belts, but then again, what do I know?
Old 11-10-2015, 07:20 PM   #8
Well that is not a belt.
Old 11-10-2015, 07:37 PM   #9
LTHatch
Drives: 2013 Yaris Hatchback L
Ern-diz: Do you have anyone who can start the car while you pin point the noise under the hood? You'll get a better idea what it can be by where the noise is coming from.
LTHatch is offline   Reply With Quote
Old 11-11-2015, 08:47 AM   #10
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
It may be the starter gear not retracting fast enough.
Old 11-11-2015, 09:31 AM   #11
ern-diz
ern-diz's Avatar
This makes a lot of sense to me because again, the sound reminds me of what you hear when you absentmindedly go to start a car that's already running.
If that's the case, what's the fix? New starter?
Old 11-11-2015, 09:51 AM   #12
Bluevitz-rs
Well the starter comes off pretty easy, so you could pull it out and check it out first. Or get a re-manufactured starter that you could have on hand and return if it's not actually needed. The starter might just need to be cleaned or lubed.
Old 11-11-2015, 11:58 AM   #13
ern-diz
ern-diz's Avatar
Gotcha.
Thanks for the info.
Old 12-04-2015, 07:30 PM   #14
ern-diz
ern-diz's Avatar
Got a better video. Plan on mentioning to service advisor at next service, but your input is valued. Wondering if I should even wait until next service, or get it in sooner. I'm not mechanically inclined enough to tell, but my sisters boyfriend manages a Firestone and didn't think it was the starter. I couldn't get it to make the sound for him, but he saw the video. Thanks in advance.
Old 12-04-2015, 08:04 PM   #15
I does sound like the starter solenoid is sticking and the starter gear is staying engaged too long.
Old 12-04-2015, 08:40 PM   #16
ern-diz
ern-diz's Avatar
Okay, thanks for the feedback.
Something I should have looked at sooner than later?
Old 12-04-2015, 08:45 PM   #17
Yes. Replacing the starter now is far easier/cheaper than replacing the damaged flywheel later.
Old 12-05-2015, 05:45 AM   #18
bairjo
Screech when starting....
Vitz starting issue Xuhaib DIY / Maintenance / Service 1 10-25-2013 06:13 AM
When cold starting, almost sounds like opening a fresh 2-liter Coke bottle Shinare DIY / Maintenance / Service 8 06-03-2013 04:18 PM
2009 Yaris starting issue -need help cudchew DIY / Maintenance / Service 15 12-16-2011 02:24 AM
Problems starting the engine fmicle General Yaris / Vitz Discussion 10 10-07-2009 08:48 AM
Starting Engine - Yaris Hatchback M/T gbuks General Yaris / Vitz Discussion 2 11-06-2008 12:24 PM
