![]() Drives: Toyota Vitz Join Date: Oct 2015
Need help on engine coolant check
I am not a car expert so pardon my novice question. I want to properly check engine coolant (locally called radiator water here in Bangladesh). A local mechanic is telling me that my car needs to be added engine coolant. I have checked the user manual and it suggests that I need to check engine coolant reservoir to check if it needs more fluid. On the whitish reservoir box the pink fluid is above 'full' mark but if I open the radiator cap than the pink fluid is not visible. Should I top up engine coolant?
The fluid will never be up to the cap when cold, but should be visible in the neck when you open the cap.
I thought mine was leaking because it was below the low mark when checked end of last year. I purchased antifreeze from Toyota and I filled it. Now its above the full line.
Would that cause any issues? |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
| check engine code P0101 | bugg_master | Performance Modifications | 6 | 09-24-2016 01:41 PM |
| 2SZ-FE custom air intake check engine light | JDM::RSTLESS | DIY / Maintenance / Service | 8 | 08-17-2014 11:42 AM |
| check engine light, engine turns but not start | willygoodness | DIY / Maintenance / Service | 10 | 07-23-2012 05:10 PM |
