![]() Drives: Yaris 2008 Join Date: Apr 2013
BRAKE INSPECTION HELP
Hello everyone - before i ask the question below are my car details:
a year ago, the brakes started making a slight squealing noise (still present) ![]() but below are details:
now my question: 1) how can there be such drastic difference in measurements for these 3 guys 2) how come the toyota guy says that rear thickness when new is 5mm and if thats so how come mineke one gave 10 and 10 written on his service form. 3) what do i do, shld i hold off a brake change or just get it done. 4) what are the actual original pad thicknesses and what thickness should i replace them. |
![]() Drives: lowered/ exhaust Join Date: Apr 2016
As an expert Toyota technician I can say that the rear brake shoes start to 4-5mm in thickness. It is possible that mineke didn't even measure your brakes just looked at them and noticed they weren't at the point to be replaced.
just to reconfirm - what you are saying is that the rear break show on the yaris is about 5mm thick (when brand new).... just making sure i understand.
Rear shoes don't wear out as fast as fronts because of the breaking ratio (80% front brakes and 20% rear brakes ) furthermore a Yaris is such a light vehicle that it doesn't require much brake force to stop the vehicle and thus your brakes will last longer then most other cars. I currently have a 15 Yaris and previously a 10 sedan. My sedan had 67k miles before I sold it and the front brakes were still at 9mm (this vehicle was an automatic)
#6 | |
also - is there really a small inspection hole behind each wheel to inspect the brake wear...
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
The official numbers from Toyota are 12mm standard thickness and 1mm minimum thickness for the front disc pads with the rear shoes being 4mm standard thickness and 1mm minimum thickness. So if you're at 8mm front and 3mm back than you have plenty of brake life remaining.
The front discs can be inspected just by taking the wheel off but for the rear drums you need to take the brake drum off the hub to inspect the shoe thickness. |
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 09:50 AM |
| BRAKE INSPECTION HELP | Abk911 | DIY / Maintenance / Service | 0 | 06-27-2016 07:13 PM |
| red hot brake shoes | tommo | DIY / Maintenance / Service | 1 | 08-31-2011 08:34 PM |
| Brake inspection at 92,000 miles (original brakes)... | Kal-El | General Yaris / Vitz Discussion | 3 | 10-03-2010 02:00 PM |
