![]() ![]() Drives: yaris 2005 Join Date: Mar 2016
Air Conditioning Sight Glass i Location pls !
Hi All
Can anyone guide where sight glass for airconditioning system to check the refrigrent is located. |
If you are looking into the engine bay it is near the front left (passenger side) and located on the hard metal a/c line. It is a small circle window.
Fwiw, i've never had been able to match up exactly with what the manual says I should see. I just see some clear fluid in there and a small bubble. My a/c has always worked fine. Imo the trick is to run the compressor every week or so to circulate the oil in the system
my eye sight is worst than i thought can you post a photo pls
Pictured within the red circle from left to right are:
Pressure sensor Sight glass High pressure schrader valve
| Need help troubleshooting air conditioning | davislau | DIY / Maintenance / Service | 7 | 07-15-2015 10:54 AM |
| Air conditioning filter | Geelmeel | DIY / Maintenance / Service | 41 | 10-31-2010 09:02 PM |
| Liftback Air Conditioning (Cabin) Filter info | Snappy | DIY / Maintenance / Service | 24 | 10-01-2010 06:36 PM |
| air conditioning | markpeppie | General Yaris / Vitz Discussion | 34 | 06-20-2006 01:17 PM |
