Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 07-02-2013, 12:02 PM   #1
swifty
Drives: 2007 Yaris
Battery drain issue
Hello everyone,
I have a 2007 yaris and have an ongoing problem with battery drain when the car isn't running. I can let the car sit for weeks without running it and there doesn't seem to be an issue so I don't think there's a short or major drain while the car is idle.
The issue is, however, that if I run the radio for 30 min or turn on the headlights for as little as 5 min without the car running, the battery dies and I have to jump the car to start it and recharge the battery. I have replaced the battery so I did rule that out as a culprit.
Is this normal for a yaris? Do those batteries drain that quickly when in use and without the car idling?
I've been left stranded at stores numerous times by shutting off car, walking up to the building, realizing the lights are still on, and immediately going back and turning them off (no more than 4-5 min time expired).
swifty is offline   Reply With Quote
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
Ohm's Law and Setting Amp Gain _S7V7N_ In Car Entertainment + Electronics (audio / video / alarm) 24 03-13-2012 10:34 PM
Battery drain by radio circuit dslc DIY / Maintenance / Service 2 08-02-2010 05:21 PM
Battery Current Drain karlb General Yaris / Vitz Discussion 3 12-09-2008 05:28 PM
