![]() Drives: Vios 2009 Join Date: Feb 2016
RANDOM ELECTRONICS RESET
Hi all! I'm from the philippines and i own a 2009 vios which is the same as the yaris sedan. My car's electronics will randomly reset cluster light and gauges blinks then dies , radio shuts off, power steering doesnt work, headlight/fog light/indoor light flickers this happens in a couple of seconds the everything will work again with the exception of the power steering which needs another start up to make it work. This happens usually at night when i have the lights on. Battery is OK. Alternator is OK... The only thing i notice is i don't have passing lights(when my HL is off, i have Hi/Low Beam when it is ON) and my speedo doesnt go down to 0 it just stays at between 5-10kph when idle.
Scanner detected the codes: C0200 : front current speed sensor RH Circuit C0205: Front current spped sensor LH Circuit ABS/VSC NOT OK MAIN BODY NOT OK are any of these codes related to the issues i have? If not what could be the problem? Thank you, YARIS WORLD. |
| Engine runs fine after ECU reset, poorly shorty after | Zachccccc | DIY / Maintenance / Service | 30 | 01-21-2016 10:41 AM |
| Needs some help with a very random random misfire | Echo02 | DIY / Maintenance / Service | 8 | 03-28-2013 11:28 PM |
| Yaris Verso: Reset power window jam protection | togo | DIY / Maintenance / Service | 3 | 01-10-2013 11:03 AM |
| Reset ECU ? | packetrace | Cosmetic Modifications (Exterior/Interior) | 6 | 09-01-2011 06:27 PM |
| Random feature | Kaotic Lazagna | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 12-17-2006 06:24 PM |
