![]() Drives: Yaris 1.5 S-Limited Join Date: Jul 2016
HELP: Yaris Matic Idle RPM Drop
Hey guys, I joined the forum because I have been facing this in solve problem with my car.
My car is a 2010 Toyota Yaris 1.5L The problem is when ever I'm in Drive than hold the break the rpm will drop to 500 and shakes the engine. This also happen during neutral it sometime drops to 500. Especially with the ac on. Is there any solution on how to fix this? Thanks |
Try cleaning your throttle body.
belt
tighten the serpentine belt. Since this cars don't have an automatic belt tensioner the belt get's loose after a while. Mine used to do the same whenever I had the engine at Idle it would bog down on the rpm and almost die. Didn't do it anymore after tightened up the belt just don't over do it.
Thanks for the input. I have done the following since my post:
- Clean Injectors - Clean TB - Carbon Clean - Clean MAF - No vacuum leak Yet I still get the vibration and rpm drop during idle. I will try to tighten the serpentine belt. Is there any other solution? |
normally with AC turned on the car should rev up.
Is your car battery good? my battery was really bad and i would have bad idling (manual transmission)
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 04:55 AM |
| New Yaris race car | Jason@SportsCar | Tracking, Racing, Auto-X Forum | 83 | 11-01-2012 03:32 PM |
| Just bought a new Yaris | Connoisseur_of_fine_cars | General Yaris / Vitz Discussion | 46 | 09-10-2011 11:49 AM |
