09-10-2016, 02:09 PM | #1 |
Drives: 2007 Yaris S Sedan Join Date: Jan 2016
I'm getting ready to install My mostly rebuilt manual trans
I pulled the transmission because the synchros are going bad I toke it to a trans shop and the clutch was sometimes chattering and just starting to slip so I had the flywheel resurfaced the clutch looked ok butt I'm thinking the spring plate got weak I was reading that the flywheel bolts are a stretch bolts so i ordered new bolts butt i think I've seen different torque specs to reinstall them I've seen the axle nut torque is 160 ft lb I was wondering if there are any other torque nuts or bolts I need to know
2007 Yaris sedan s manual 5 speed silver 2014 Tundra TRD off road double cab 5.7 blue ribbon metallic |
09-10-2016, 10:01 PM | #2 |
2ZR swap. DO IT! Ask how!
The flywheel bolts are indeed stretch bolts: 38 ft-lbs, then 90°. Technically, all bolts have a torque spec. I followed the repair manual for my R&R.
09-10-2016, 11:33 PM | #3 |
Is there a link to a repair manual that steal works. I've had a hard time finding good links.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Yarisworld.com DIY Manual v3 | vodkalush | DIY / Maintenance / Service | 101 | 06-25-2024 12:10 AM |
Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 08:47 AM |
manual trans fluid | d2dailly | DIY / Maintenance / Service | 65 | 02-14-2009 07:38 AM |
Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
Yarisworld.com DIY Manual v3 | vodkalush | Downloads for Registered Members | 30 | 01-21-2007 10:54 PM |
