Old 10-17-2013, 03:13 AM   #1
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Water leak in Hatch
During long rain storms I have been collecting water in my trunk area where the spare tire is. It really turns into a swimming pool in there sometimes if its a down pour. I have been keeping my drain plug off because of this. Been going on for about a year now. Keep forgetting to ask if their is anyone else having this issue.
I have tried the hose technique by leaving the hose on top of the car pouring water around the hatch door. I can not seem to duplicate the issue. My hatch seal looks mint. No build up of any kind.
CRX's have this issue but its a pinch weld near the hatch lift that need to be resealed with some weather sealer.. does the Yaris have this issue also that anyone knows of?
-Derrick-
Old 10-17-2013, 05:35 AM   #2
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
A lot of water came down here in the last days, but mine stayed dry inside...
Maybe it comes in near the lamps?
dj92 is offline   Reply With Quote
Old 10-17-2013, 06:29 AM   #3
bronsin
bronsin's Avatar
Pressurize the inside of the car with a shop vac set on blow.
Go around the hatch area with a cigarette and watch for the smoke to blow.
(you should hear how I retrieved the dip stick for my in ground oil tank with a carrot and a piece of 1 and a half inch pvc pipe!
Old 10-17-2013, 06:53 AM   #4
To do that you would have to plug the two vents that are hidden under the bumper, just below the taillights. The vents allow air to escape when you close the doors, so they have a pretty significant vent capability that would prevent a small leak from being visible during pressurization.
If the hatch seal shows no sign of moisture after doing a spray down, I would pull the tails and check their gaskets. The two places to check if it is not the tails is the antenna gasket and the body seam seal under the black rubber roof strips. (But, my bet is on one of the tail gaskets being the culprit)
Old 10-17-2013, 08:18 AM   #5
ilikerice
ilikerice's Avatar
Ahhh.. I do believe it could be the tails. Didn't think of that.. I know they don't have any type of gasket foam so I'll makeshift one this weekend if I got time.
The carrot and PVC pipe thing.... curious if there is a rabbit involved. Prob not. But would be cool to have a trained rabbit to get that. Lol
Thanks for the input guys
-Derrick-
Old 01-20-2015, 05:25 AM   #6
El Kapitan
Senior Veteran
Drives: 2007 5 door hatchback
did your leak stop when you tried this solution? i also have water build-up in my spare tire area.
El Kapitan is offline   Reply With Quote
Old 10-17-2013, 09:56 AM   #7
bronsin
bronsin's Avatar
I put the pcv pipe over the stick down in the 550 gallon tank. It was still upright.
Then I dropped a carrot down the pipe that I knew was a close fit in the pipe. I pushed the carrot down the pipe so it wedged the stick against the pipe.
Then I pulled up the pipe.
QED
Old 10-18-2013, 11:04 AM   #8
ilikerice
ilikerice's Avatar
HAHA.. clever
-Derrick-
Old 01-12-2015, 08:10 PM   #9
mattymo
Drives: 09 LB
I'm chasing hella leaks. Fixed tail gaskets. But now water is comin in from the 2 layers of sheet metal forming the lip that tge trunk weatherstrip goes over. They're not fully welded together. I also have mystery leaks coming down the rear strut towers. I think it may be the hatch lid wire grommett, and/or the antenna. Leaky bitch. Frustrating. Weird smell...not the typical wet dog mildew smell i would expect....more like old hotdog water????
Sent from my GT-P5210 using Tapatalk
mattymo is offline   Reply With Quote
Old 01-20-2015, 03:07 PM   #10
CoryM
Drives: 2009 5-door, 5-speed
My 09 hatch has just suddenly developed a leak in the hatch. Hatch rubber is fine, so will have to tear it apart. I'll post results when I find them.
Cheers.
Old 01-20-2015, 10:55 PM   #11
El Kapitan
Senior Veteran
lol, we're both in the same area. it sure has been wet around here recently! let us know if it turns out to be your tail lights. i'll do the same. btw, just to save some time and let you know: no local parts stores sell replacement gaskets. you'll either have to do a dealer search or try the DIY approach that most others here have used with various types of sealant. (btw, one of the guys at a parts store where i went is also having the same problem. crazy!)
Old 01-21-2015, 07:48 AM   #12
Kar98
Drives: 2011 Scion tC
Just to pile on, we had one of these events were water is falling from the sky for several days for reasons unbeknownst to me here in Texas, and once it stopped and the ground wasn't wet anymore, I could see some fluid dripping from the area where many cars used to have the gas tank.
Kneels down, look puzzled at the drips, jiggle that stop, dribble turns into a gush, now concerned I dip my fingers in and give it a lick... hmmm, neither gas nor brake fluid... Pull the stop and blah blah blah, sure enough, there was water accumulated in my spare wheel well too. And the spare is flat.
Old 01-21-2015, 08:36 AM   #13
ilikerice
ilikerice's Avatar
I changed out my Tail light gaskets and I still have leak inside my spare tire. I gave up. I just pulled the drain plug and leave it open. Water drains out from there now so i no longer worry about hitting the brakes too hard and water rushing to the front of the car.
My car is now in the garage, but I may tackle this mystery after I get it back on the road.
-Derrick-
Old 02-19-2015, 01:47 AM   #14
El Kapitan
Senior Veteran
my car leaks from somewhere up high. not the tail lights. i'm still trying to find it but the water stains behind the paneling start well above the tail lights. this could be the case with yours too. i sealed the weather stripping, the strut connections for the hatch, the wiring gromet rubber, the windshild fluid gromet. all that's left is the antenna and the area where the hinges of the hatch are connected to the top of the car. if sealing these last areas works, i'll post back.
Old 01-21-2015, 11:04 AM   #15
thestranger
Drives: 09 3-door LB/MT
Mine does the same thing. It accumulates in the right corner of the hatch, so it definitely looks like it's coming through the tail light. Smells up my car like mildew (Louisiana).
thestranger is offline   Reply With Quote
Old 01-21-2015, 08:55 PM   #16
mattymo
Drives: 09 LB
Check tailight gaskets...i added foam/aluminum insulation to mine. Check sheetmetal seems at all edges, especially the ones the trunk gasket covers.....i quicksteeled these gaps....much improvement. I still have a leak from up high somewhere....roof or window sheetmetal gaps probably.
Old 01-23-2015, 07:03 PM   #17
bkrownd
bkrownd's Avatar
Drives: 2010 Yaris "5-door"
My 2010 hatchback has leaked from around the driver side corner of the hatch/taillight since nearly the beginning. I figured it was "just me" since I live in the rainiest city in the country, but apparently others are enjoying the occasional dribble down the hatch floor as well.
bkrownd is offline   Reply With Quote
Old 01-27-2015, 03:31 AM   #18
El Kapitan
Senior Veteran
for me, it was indeed the rear tail lights leaking, as with so many other people. after removing, cleaning, and sealing, the problem has been resolved.
DIY: Hatch Popper using Scion IQ Hatch Handle (2006-2011 Liftback) CTScott DIY / Maintenance / Service 15 12-30-2015 06:27 PM
Water Leak! Failed Relays cfeng DIY / Maintenance / Service 0 12-13-2010 05:21 AM
Water leak on carpet Rick1234 General Yaris / Vitz Discussion 2 10-31-2010 09:10 PM
07' HB Water Accumulation in hatch bobolinko General Yaris / Vitz Discussion 9 09-26-2010 02:55 AM
