guy2can
P/S Pressure Switch P0552
Hi all,
Had to change the power steering pressure switch (PN: 89448-51010)on my sons 2004 Echo HB, the code P0552 was coming up once the car was started after every code clear. I tried cleaning the connector, but in the end went to the wreckers and paid $20.00 CAD for a used one. From the dealer and parts places, this little baby is $275-300 CAD. It is about $125. USD at Autozone under PN: PS442. So changing was fairly easy with the car on ramps and accessing the switch from below with a 1 1/16 wrench. The hardest part was getting the connector to release without breaking the lock. The K Ohms readings in the amber column were alot more on the bad sensor. cheers, |
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 09:42 PM |
| DIY yaris III fog lights installation | karloslatynos | Third Gen Yaris General Discussion | 53 | 11-12-2017 04:03 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
| screw more psi in the tires. | thebarber | Fuel Economy Forum | 43 | 05-04-2009 05:46 PM |
