10-23-2016, 05:22 PM | #1 |
Drives: '08 Yaris Sedan, Aero Package Join Date: Oct 2008
Winter Boot Time
Sadly today I removed the summer performance sneakers in favour of the winter boots and their OEM steelies and covers.
Gave the steelies a fresh coat of Tremclad semi-gloss black and after scratch repairs hit the covers with some dark grey metallic. Should look better than the OEM silver covers against my silver commuter sedan.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots. |
10-23-2016, 05:56 PM | #2 |
Drives: 2007 yaris 3 door Join Date: Sep 2015
I don't believe you did any of that.
do you have any proof? I didn't think so... |
10-23-2016, 08:29 PM | #3 |
I should hit my steelies with something interesting
10-23-2016, 11:43 PM | #4 |
It's not gonna snow till January
10-24-2016, 05:02 AM | #5 |
10-24-2016, 02:29 PM | #6 |
Got my winter steelies on today. Doing nothing to pretty them up. Rat Rod Steelies FTW!
10-24-2016, 04:22 PM | #7 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
damn you guys are early.
I don't throw mine on until it is consistently always below 7 degrees. There's a reason I get 6-8 winters out of my tires though. I always see people with tires installed early October and they are either brand new or practically bald, they just wear down so darn fast in warmer temps
No one ever wants to give a Yaris the point by... |
10-24-2016, 04:52 PM | #8 |
Drives: 2008 Yaris 5dr LB Join Date: Aug 2016
the temp is low enough for winter tires, unless you are waiting for the first snow!
those who need help from the garage to switch out theirs need to be proactive, to beat the long lines. I've mine on since last weekend. |
10-24-2016, 05:10 PM | #9 |
This will be my third season on my second set of winters. The last week of October/first week of November is not too early. Daytime highs of 12c do not cook winters. Left it a little late one year and got hit by a surprise snow storm while still on my 1 seasons. Never again!
10-24-2016, 06:18 PM | #10 |
I get it of time is limited due to the line up at the garages, but I'm talking about when you swap them yourself.
to each there own I guess, but day time highs of 12 and 15 degrees are to warm and will increase wear. Heck even 7 degrees will cause wear, they just perform better at those temps than all seasons. In other words the "optimal" time to use them in regards to wear is completely different than the optimal time for performance. If you baby the tires on warmer days then that will likely help, but with the random warm spikes in southern ontario's weather added up over 4 or so years easily leads to 1 or 2 seasons less over the life of the tire.
10-24-2016, 06:40 PM | #11 |
It's cold enough when I leave at 6am for London
10-24-2016, 06:49 PM | #12 |
Winter Boot Time
So am I. My last set got retired with gobs of tread left on them. The rubber compound just got too hard due to getting so damn old. As barber has eluded to, this time of year the bulk of drivers are hitting the road in the morning at 2c and again in the afternoon/evening at 6c. Your argument doesn't really stand imo. Sent from my iPhone using Tapatalk
10-24-2016, 07:54 PM | #13 |
like I said, to each their own. I'm on the road at 5am and drive home between 7 and 8:30pm. I personally just don't feel the benefits of running winter tires at these temps outweigh the risk of possible premature wear due to fluctuations in the temps.
Just because 7 degrees is seen on the thermometer at a point in the day does not necessarily that is the ideal time to run those tires. As most manufacturers state when the temperature is consistently below 7 degrees is ideal. I do agree however that the tread does harden up after 5 or so years and they need to be replaced regardless of tread depth. But me being a poor student I keep the tread as deep a possible because when i re sell them in 6 or so years the vast majority of people don't look at tire age, they only look at tread depth. My swap time are obviously purely based on economy, not necessarily on performance. If my wallet wasn't so light I'd likely have my tires on in mid November and off at the end of March
10-25-2016, 10:19 AM | #14 |
ive never seen significant wear by running them @7c
my view of it is that id rather wear my tires slightly then end up shiny-side down somewhere
10-25-2016, 11:42 AM | #15 |
My last thoughts on this;
- since typically we invest more on summer rubber than winter, why concern yourself with 'premature' winter tire wear caused by the odd spike in temperature. - how far do you have to drive before summer tires warm up enough to eliminate the flat spot that develops sitting for extended period of time in cold weather? For me it's about 4 kms before the shaking and thumping disappears. - since tire change-over involves brake servicing and wheel cleanup, I prefer not to do this in single digit temps. Good discussion you started here MUSKOKA. ...and I'm done.
10-27-2016, 09:58 AM | #16 |
10-27-2016, 11:46 AM | #17 |
Almost always we'll see snow make an appearance in October. Now you won't see any more until January
10-28-2016, 01:03 AM | #18 |
does anyone treat their tires before storing them? I spray down my winter tires with silicone and seal them in tire bags for the summer. this prevents them from getting harder. (unless they are crappy blizzak tires) (I also live in the desert climate)
I usually buy 2 new tires every year, rotate the last fronts to the rear, and pitch the old rear tires. there's no way I could have them last more then 2 winters... |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Official! Here's the 2014 Toyota Corolla | Kal-El | Off-topic / Other Cars / Everything else Discussions | 31 | 01-16-2014 12:25 PM |
Best winter tire size | SECProto | Third Gen Yaris General Discussion | 3 | 12-01-2012 10:37 PM |
Winter tires and road hazard program w/Tire Rack | mikey4226 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 10-04-2012 11:07 AM |
First time AutoX with the Yaris | Keith Tinari | Tracking, Racing, Auto-X Forum | 52 | 11-20-2009 02:38 AM |
7-17-09 Last Day for Time Attack Event @ CFRC | SAKU | Tracking, Racing, Auto-X Forum | 1 | 07-14-2009 02:10 PM |
