shiny for 10 minutes
I bought a weaponR exhaust manifold. it was shinny. I only got to look at it for about 10 minutes.
now it's not shinny anymore :( unshinified |
Yeah but header wrap makes it look legit!
it also helps with flow and scavenging. plus, that computer being 6 inches from the manifold scares me...
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
You have great taste sir.
Personally I think you went a bit over the top with the wrap, but it does look very nice. ![]() I've been running mine for nearly 2 years with no wrap or heat shield, and never ran into any problems.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
tri Y makes for better low end torque. :) I didn't by the DC one because i'm not looking for top speed. I am looking to go quickly....
and the wrap helps on any engine. higher temperatures (to an extent) creates higher pressure/flow, which creates better scavenging from sister cylinder, which is exploited by the try Y pipe. (as the theory goes) |
![]() Drives: 08 Yaris hatch back Join Date: Nov 2016
Sweet looks awsome
![]() ![]() Drives: 01 Yaris TS Join Date: Jan 2017
Looks good, how does it perform? (butt dyno ?)
I have a spare stock manifold.. I should wrap it for educational purposes
#8 | |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
be sure to port-match the header to the gasket. There is some shrouding on them. Plus while your at it, investigate the inner joints & blend as necessary. Mine had some really rough joints
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
XP10 Enthusiast
Drives: 2000 Echo Coupe Join Date: Jan 2017
That looks awesome! Now I want one
![]() I always wondered if this Yaris parts fit in a 1st gen US-Spec Echo. It's the same engine though.
'01 Yaris 5dr Hatchback M/T | Blue Streak Metallic [RIP] '00 Echo Coupe A/T | Absolutely Red [Still Alive] |
Obsessed with 1.5L
^ outlet flange bolt pattern is wider for the yaris and the outlet is in a slightly different position. You can probably use one...just modification to your front pipe will be needed.
XP10 Enthusiast
You mean like replace the bolt pattern with another aftermarket pipe? or maybe adapt the OEM outlet flange? I was thinking about adding a aftermarket pipe and/or exhaust from newer models and customise to fit....
| Tags |
| exhaust manifold, exhaust wrap, weapon r, weapon-r |
| Yaris dead then minutes later starts fine | vinny121 | DIY / Maintenance / Service | 6 | 02-27-2015 09:01 PM |
| DIY how to change you belt in 10 minutes without breaking VVTI solenoid | YarisSedan | DIY / Maintenance / Service | 2 | 04-12-2013 11:41 AM |
| Shiny glass-looking plastic flakes from HVAC, and windshield | LugNut | New YARIS Purchase Forum | 15 | 11-20-2011 11:39 AM |
