Old 11-03-2016, 02:34 AM   #1
rabbito
rabbito's Avatar
E85/Flex Fuel Write Up
so many people are contacting me regarding E85 so i am doing a write up on E85..no, im not a professional tuner like some people out here doing big things..im just doing a small budget build switching jdm counter parts and doing multiple test as my personal hobby...for professionals, correct me if im wrong 👌
1. yaris in asia is supported with E85 in asia..same 1nz engine and yaris that we use back in U.S..no, its not going to rust your sh*t inside out..this myth is busting peoples balls...
2. you need larger injectors for E85 fuel conversion so i went with 1JZ...some people use 2ZZ or whatever toyota injectors depending on their need...i needed 30% larger than stock 1NZ injector which was the 1JZ injectors..i trimed the side off and put E85 plug
3. E85 plug is thing that goes behind the injector to convert flexfuel...this piece of plastic plugs costed me $20...i trimed the 1JZ injectors and plug this behind the back of injectors..
4. no, you dont need a freaken ecu or tuning when you go 30% larger injectors...unless your doing fuel tuning with aftermarket injectors..we are not talking about aftermarket injectors with chiptuning here...basic jdm counter part conversion
5. no, converting to E85 does not gain HP...you must use ecu tuning system..if your on a budget, you can just do advance timing and control fuel injection with cheaper piggy back ecu
6. no, it does not mess up your engine oil etc..its a clean high octane fuel..also has this funny corn smell...lol..
7. you will lose 20% more fuel around town, its not good for traffic jam etc...you will get good mileage on the highway..🖒
***i see video of E85 converted cars having issue with starting in the morning(frs, brz, civic etc)..i started to have this issue too where i have to crank at least twice in the morning to start an engine..add a gallon of regular gasoline...it solved the problem like a magic(i tested them out after reading off of this dude who had starting issue on his E85 converted brz)👌👌👌
FB_IMG_1478149773915.jpgFB_IMG_1478149734764.jpgFB_IMG_1478149696351.jpgFB_IMG_1478149610271.jpg
Sent from my SM-J710F using Tapatalk
Cosmetic: Toyota red emblem
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
Do any Yaris owners use premium gas ? DanMC Third Gen Yaris General Discussion 38 11-06-2013 11:36 AM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 04:34 AM
