Old 02-02-2017, 10:21 PM   #1
BLOODY_STONE
Drives: 2009 toyota yaris 1.3 sedan
Amsoil manual gerabox oil issue?
anyone had an issue with amsoil mtf 75-90 fully synth. GL-4?
car doesn't feel smooth in shifting as before,, it was on mobil 1 , same specs
help?
BLOODY_STONE is offline   Reply With Quote
Old 02-02-2017, 10:55 PM   #2
SirDigby
Drives: 2007 yaris 3 door
that does not make sense. amsoil should be higher quality.
Old 02-02-2017, 10:59 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
No issue with amsoil.
I used Castrol at first then quick switched to Royal Purple. Now I'm running Amsoil and it's been so much better.
Sent from my SM-G930W8 using Tapatalk
Old 02-03-2017, 09:49 AM   #4
tmontague
tmontague's Avatar
Was there a big difference between the RP and the Amsoil? I can easily purchase RP from my local CT but if Amsoil is better than I may try and source it.
FWIW, I'm currently running Redline 75w90 GL-5, it shifts smooth but still grinds the odd time in reverse.
Old 02-03-2017, 10:12 AM   #5
IllusionX
It's normal to grind shifting into reverse.
I did not have the correct RP oil, so things were not better than Castrol. I had the RP synchromesh gear oil, which wasn't really meant for our transmission.
I used to grind 3,4 and 5th gear up shifts when reving high. As soon as I put Amsoil in, no more. Just going from 3rd to 5th but now that we talk about it, I haven't heard it grind doing it anymore.
I still have some random grinding going into 1st from a rolling stop, but it's rare now.
Old 02-03-2017, 03:10 PM   #6
BLOODY_STONE
me having a grind when going to 1st all the tiime 😄😄
Old 02-03-2017, 08:45 PM   #7
IllusionX
Try double clutch.
Old 02-03-2017, 07:24 AM   #8
BLOODY_STONE
ok ,, maybe something went wrong in the oil change ? or maybe it is the flywheel dying ?
Old 02-03-2017, 09:51 AM   #9
tmontague
tmontague's Avatar
What do you mean by "it doesn't feel as smooth"? likely an issue with the fluid or amount, could be your flywheel/clutch but less likely
Old 02-03-2017, 09:58 AM   #10
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Ive been running amsoil for over 100k in my trans with no issues.
Your clutch may be on its way out. Shifting tends to get notchy when its near the end of its life
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 08:18 PM
Manual Transmission...Safety Issue!!! twocvforme General Yaris / Vitz Discussion 189 10-31-2010 12:00 AM
Question About Engine Oil Kaotic Lazagna Off-topic / Other Cars / Everything else Discussions 21 08-29-2009 04:08 AM
About Engine Oil Changing Manual hans_fh DIY / Maintenance / Service 4 03-03-2007 11:20 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 09:16 PM
