Old 02-17-2017, 02:14 PM   #1
Pinchlite
Drives: 2007 yaris HB
Led bulbs no high beams(I thought) solved
These are the lights.
https://www.amazon.ca/NIGHTEYE-Headl.../dp/B01J7KJF0E
I thought the highbeams did not work(daytime test)and was relying on the dashboard blue highbeam indicator.From further reading this is what is needed to get the blue highbeam indicator back
Headlight Load Resistor Kit - H4 LED Headlight Bulbs
https://www.superbrightleds.com/more...ht-bulbs/2179/
Or this fix(scroll down)putting in resistor.Luckily I can get these around the corner and will try tomorrow.This is for a cruiser so not sure if it works for a yaris though.
http://www.fjcruiserforums.com/forum...m-circuit.html
(link to resistor for any Canadians)
http://www.thesource.ca/en-ca/tvs-an...ack)/p/2719018
As far as the brightness goes they dont appear as bright in the daylight.I think that is because of the color temperature?
I will see tonight how they look.
Hope this helps others.
Old 02-17-2017, 03:19 PM   #2
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
This is starting to look like an expensive solution. I wonder why no one seems to be selling straight plug-compatible LED versions of regular headlight bulbs. They don't even have to be super bright.
Sent from my phone with Tapatalk. Please excuse any typpos.
tarkus is offline   Reply With Quote
Old 02-17-2017, 03:23 PM   #3
Pinchlite
If the resistor works then not expensive fix at all.
I will find out tomorrow after putting in resistors and update.
As far as the led's go they are comparable in price to good name halogens.
They use less amperage,should be brighter and last longer.
Old 02-17-2017, 05:08 PM   #4
tarkus
tarkus's Avatar
So around $50 + $18 for a pair of bulbs. Still looks a little pricey to me. However, given that the 2nd gen Yaris is a little older technology wise, maybe this resistor thing won't be needed.
Old 02-17-2017, 05:16 PM   #5
Pinchlite
highbeam indicator light
The bulbs I linked were not expensive at all in my opinion.
The load resistor is optional.
Buying seperate resistor($6.99 CAD) and doing the mod may resolve issue.
The issue being that the blue highbeam light in the instrument cluster does not light up when highbeams are activated.
I could probaly get the resistors much,much cheaper but I can get locally for the $6.99.
You need to read my entire post carefully.
I have 2007 2DR HB btw.
I will be heading out in a couple hours to test the new lights in the dark.
Madison, WI meet feeler suckerface Great Lakes 8 09-20-2016 03:45 PM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
Prius C / Yaris LED foglight bulbs cali yaris Off-topic / Other Cars / Everything else Discussions 1 06-15-2013 08:55 PM
Thinking about buying LED Light bulbs and Projector head lamp LA Yaris California 15 02-07-2010 03:12 PM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
