![]() ![]() ![]() Drives: 07 yaris hatchback Join Date: Dec 2016
Water leak problem
07 H.B water leak just in the right rear floor and truck ???? Any one had the same problem any idea ??? Thank u
Sent from my SM-G935T using Tapatalk |
Yaris right rear water leak
I was getting a wet place and found two possible sources on the right rear floor/seat area after a total rear bench delete. I could see ground through a hole about 3/8 inch diameter. (Even if this was for a locating prong on the seat frame, it would leak.) I covered it with a piece of PVC tape and still notice a minimal wetting at the large circular hole plug in the same vicinity.
Thank you bi the way how u take the backseat is easy ??
Hubcap Enthusiast
Drives: '09 3-door 5-speed Join Date: Jan 2016
Check your taillights. Lots of the 2nd gen hatchbacks get leaky there. Run some water down the channel outside the hatch seal, above the taillight, and see if any of it winds up in your spare tire well.
The leak is somewhere in there
![]() Sent from my SM-G935T using Tapatalk |
Jackpot found it thanks scratchpaddy taillight
| Newbie with an exhaust leak on his '06 Yaris | ToYarta | DIY / Maintenance / Service | 49 | 01-03-2019 01:50 PM |
| Water leak in Hatch | ilikerice | DIY / Maintenance / Service | 40 | 10-22-2016 03:46 AM |
| Air Conditioner Noise & Leak? | Dawn Eshelman | DIY / Maintenance / Service | 116 | 07-21-2015 02:22 PM |
| Unique Smell from Air Going Through AC Blower | EddieCabael | DIY / Maintenance / Service | 30 | 01-19-2015 10:08 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
