Old 06-26-2016, 05:30 AM   #1
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
TB Polishing & Spacer Complete
just got the TB fully polished with TB spacer..RPM went way too high at first, had to reset battery after the modification...you do feel the hp/tq gain..first i looked down on this modification as a joke but this modification do gain hp/tq...they said you can use 60mm TB if you want but i want everything oem as possible..theres a local racing group called BRD in thailand who tested this method/product with dyno and it actually increased hp/tq..
it took about an hour with polishing and installation..
smooth rev all the way through the rpm range 😊😊😊😊😊
your free to ask me any questions..
Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 06-27-2016, 12:56 AM   #2
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
How do you reset a battery??
Sent from my LG-D801 using Tapatalk
tarkus is offline   Reply With Quote
Old 06-27-2016, 12:57 AM   #3
rabbito
rabbito's Avatar
take off the right clamp and put it back on..restart the ecu...lol 😂😂😂😂
Old 06-27-2016, 01:08 AM   #4
tarkus
tarkus's Avatar
That doesn't reset the battery :-)
Old 06-27-2016, 02:08 AM   #5
rabbito
rabbito's Avatar
you throw the battery on the floor and kick them couple times, thats how you reset them
Old 08-19-2018, 11:02 PM   #6
SUPA DUPA 1
Drives: 08 LIFTBACK & 2015 5d SE
I thought the battery reset switch was hung on the right (drivers) side of the muffler bearing bracket.
SUPA DUPA 1 is offline   Reply With Quote
TB Spacer + TB polishing rabbito Performance Modifications 6 06-25-2016 01:08 AM
Echo HatchBack 15X6.5" 42ET Nitto NeoGen 205/50R15 . Rear Spacer or not ! mpcv2000 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-10-2014 11:32 PM
Best Rear Spacer SeriousBlack Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 08-22-2011 03:44 AM
Wheel/hub spacer, PLS help evo165 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 08-18-2009 03:21 AM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-02-2007 12:38 AM
