![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
Hydrodip!!!!!!
anyone play with hydro-dip???
it's super fun! but it is difficult to get it right. I had to do a lot of practice dips before I felt comfortable to do my engine cover. it even has some flaws and issues, bit overall it turned out good. I did the other plastic parts too. my buddy says it looks super gay with it's rainbows and gold, but I think it looks good. here is the before: here is the part's after repainting and the dipping: here they are after install. you see I covered the red "Tanabe" area with a sticker. I did not like how the red looked. it was fun. here is some tips: -the bathroom fan has insufficient ventilation for dipping. (HA!) -you don't need to wait 60 seconds to apply activator, just wait for the paper to "de-wrinkle." I had a few sink below waterline on a corner wile waiting. -you will use more activator than it seems you need to. you pretty much have to over do it. this was my problem as I don't want to be wasteful. but if you don't spray enough, the ink will bind and you get tiny bubbles that pop and create holes in the pattern. I would do 3 or 4 cross hatch coatings, and I probably should have done 6. (really!) -your best dip is the first dip. after the water gets activator and ink residue in it affects the following dip. I recommend doing a bunch of testers/small things, then changing water for fresh and then doing the big pretty thing. |
| Tags |
| engine bay, engine cover, hydrodip, plasti dip, strut bar |
