Old 05-01-2017, 06:04 AM   #1
likoulou31
Drives: Toyota Yaris
Noise @2000rpm Toyota Yaris 2NZFE 2001
Hi everyone,
I have a noise I can't locate on my Toyota Yaris 1.3l 2NZFE from 2001.
I can hear it :
- With any gears.
- Clutch engaged or not.
- Around 2000rpm
- Located in front of the car.
Here's a video :
https://youtu.be/iM9_vCTEdUA
In it it's like a bzzzzbbbzzzz :)
Hope you guys will have a solution
likoulou31 is offline   Reply With Quote
Old 05-01-2017, 10:05 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Check the manifold heat shield. They eventually rust out around the bolts
Old 05-01-2017, 12:06 PM   #3
likoulou31
I checked it and there's no rust on it.
Around bolts there's no rust too.
Old 05-01-2017, 12:48 PM   #4
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Intake manifold diaphragms loose?
ncp13 is offline   Reply With Quote
Old 05-01-2017, 01:46 PM   #5
likoulou31
Where is it located ?
It's the intake gasket or something else ?
Old 05-01-2017, 01:53 PM   #6
ballast vibrating on frame?
id bet its just something thats loose and vibrating on something metal
Old 05-01-2017, 02:21 PM   #7
likoulou31
What is the ballast ?
It seems to be located under the gear shift lever. I checked yesterday but found nothing loose
Old 05-01-2017, 10:02 PM   #8
Ballast would be an aftermarket item if you had HID's.
If below shifter maybe a coin dropped in there somewhere?
Old 05-20-2017, 05:34 AM   #9
likoulou31
Today I tried to make the noise happen again.
Parked I pushed the clutch pedal so no movement in the gearbox, went to ~2000rpm and I heard that rattle again.
Then I just pushed the lever shift downward and the sound stopped at a certain position between "no gear" and 2nd or 4th or reverse...
I don't know what it can be do you guys have an idea where to look ?
Old 05-21-2017, 04:10 AM   #10
likoulou31
Hi everyone,
Could it be forks in the gearbox or the mechanism that control these forks ?
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 04:55 AM
