![]() Drives: yaris 2007 3dr hatchback Join Date: Feb 2013
cargo light not working? ( Yaris HatchBack )
Hi, my trunk light (cargo space) is not working. i changed the bulb but it still not working. I wonder where the problem is ???
( my dome light and all accessories are working just fine ) |
![]() ![]() Drives: 2008 Hatch Red Join Date: Apr 2012
Could be a bad switch. When I open my hatch it shows up on the dash as a door open. Is yours doing this? Did it used to? Might check the switch.
Yah, when i open the hatch, there is no door open signal show up on the instrument panel. if it's the switch, where is it? i cannot find it, so i don't know where to fix?
Good question. I just went and took a look at mine. It has to be built into the latch. I poked around in there but couldn't activate it. Your switch might be stuck in the open position so a little lube and a few openings and closings of the hatch might be worth a try. It doesn't look too hard to pull it out but I didn't feel like doing that.
It is part of the latch. The brown wire is one side of the switch and the white/black wire, which is ground is the other side.
Thanks you for the answers. i will try to check that when i have time. hope it's not too hard to open the hatch panel to fix it.
![]() ![]() ![]() Drives: yaris le Join Date: Sep 2014
![]() Drives: Yaris Hatchback 3 Door USA Ver Join Date: Mar 2015
Scott! do you have any diagrams for this by any chance? I have the exact same issue and although I pulled out all of the covers from my Yaris hatchback, I can't find the culprit
| Toyota Yaris Battery Light On - Repair | gabo | General Yaris / Vitz Discussion | 1 | 08-24-2011 08:21 AM |
| 2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 05:54 PM |
| test fit 06-07 Yaris 4 door fog light | winson | California | 15 | 01-13-2009 09:25 PM |
