![]() ![]() Drives: 07 yaris Join Date: Dec 2016
Can't get new drums to go over new shoes?
Went to put new brake drums and shoes on my yaris today and when I got the new shoes installed he drums won't go back on and the adjuster is all the way in. The parts are identical to the old parts. What am I doing wrong? How do I go about fixing this issue?
Make sure the wheel cylinders aren't frozen, carefully push each piston in, as you do this the other piston should move out. If it does that, then they should be ok.
Are there different size shoes? If so, the big ones go on the back. Parking brake stuck on? Sometimes you have to move the shoes up or down a little to get them on the center so the drum will slide on. |
![]() Drives: Yaris 2002 1.0 Join Date: May 2017
Have you ground the lip off the drum before you try refitting. I always do this to make sure the drum has a good start at sliding onto the shoes. And dubble check all the adjustment is off of your handbrake cable and that the cable moves freely on both sides as these can seize up. Also like the other member said in the previous reply have you compared the shoes your new ones to the old ones. There are so many little differences with these cars!
![]() ![]() ![]() Drives: Yaris T-Sport Join Date: Nov 2016
Are your handbrake cables loose enough ?
Send from OnePlus 3T |
Haven't thought of the handbrake cable. I tightened it up a bit up under the center console about 6 months ago. Would this be causing any problems? And my wheel cylinders are free btw and the parts are 100% identical other than old parts worn out.
We'll need some good pictures if you haven't figured it out yet.
Just slacked off the handbrake cable and everything is fitting better I'm moving around the shoes now trying to get it to fit. I can get one side on but not the other
Just putting this out there. Since you were able to slide one drum on after slacking handbrake but not the other, then the cable may be seized on the one side.
So guys I feel kinda stupid haha I had a toyota mechanic come by and help me. Turns out that the shoes are different than the old ones! Compared side by side the new ones were about a 1/4 inch longer than the old shoes which is why they wouldn't fit. All the holes and mounts look exactly the same but longer shoes. Is there different shoes for differnt model yaris's?
Dont worry about it mate we all drop clangers like that now and again we just dont say anything! At least u admited it! Haha. As i said on my previous post to you there are loads of different bits on these cars that are different just note it down next time you wanna buy anything for the yaris - dubble and tripple check parts with your old ones! Glad you got it sorted in the end mate!
#11 | |
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
In the UK we had French and Jap Yaris's and various engine sizes so its no wonder we had different brake options.
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
One more problem now guys. I had to replace a few wheel studs because previous garage impacted my lug nuts on VERY tight. Twist off 3 of 4 on one side. Can't get the new lugs to go in straight. What do I do now?
#13 | |
Sent from my SM-G900F using Tapatalk
#14 |
Using a lug nut, conical side out, to draw them in tight they should self align.
#15 | |
#16 |
Only had lug nuts with the closed end but used a couple washers to keep the lug nut straight and used a ratchet to tighten them in. All studs straight and seated in perfect!
#17 |
Now how do I adjust the rear brakes properly? Tighten them till I can't move the drum by hand and back them off 2-3 turns?
| air suspension thread | jerome | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 93 | 09-23-2017 02:34 PM |
| spark plug change tools | patm | DIY / Maintenance / Service | 1 | 10-17-2011 05:42 PM |
