06-03-2017, 02:55 PM | #1 |
Drives: 2010 GRAY 4DR SEDAN Join Date: Mar 2016
Tail light parking light & license plate stop working
Hi Guys,
My driver side headlight became dimmer, tried to DIY it by adding an extra ground wire...didn't work but lost my tail light, park light and license plate light in the process..I may have touch a + wire, anyway, I Found that my driver side fuse went bad so replaced it and my HL are OK. I still don't have my tail lights, park lights and license plate lights..my break lights, Dash indicators, cluster lights, signal light still works. Does anyone know where the tail light relay is located? This will be my next DIY check Thanks a lot Bob Siray2 |
06-03-2017, 02:59 PM | #2 |
Hi Guys,
My driver side headlight became dimmer, tried to DIY it by adding an extra ground wire...didn't work but lost my tail light, park light and license plate light in the process..I may have touch a + wire, anyway, I Found that my driver side fuse went bad so replaced it and my HL are OK. I still don't have my tail lights, park lights and license plate lights..my break lights, Dash indicators, cluster lights, signal light still works. Does anyone know where the tail light relay is located? This will be my next DIY check. Can anyone with this experience give me a heads up..I sincerely appreciate all. Thanks a lot Bob Siray2 2010 4dr sedan |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Installing Trailer Light Harness | vandallen | DIY / Maintenance / Service | 7 | 06-10-2024 10:06 AM |
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
DIY yaris III fog lights installation | karloslatynos | Third Gen Yaris General Discussion | 53 | 11-12-2017 03:03 PM |
License Plate question | awebb005 | Cosmetic Modifications (Exterior/Interior) | 5 | 11-11-2014 08:28 AM |
Need 07 Sedan Tail Light wiring info ASAP | atebit | General Yaris / Vitz Discussion | 3 | 09-07-2013 06:48 PM |
