Old 05-31-2017, 03:55 PM   #1
badillin
Drives: Yaris 2007
Mixing wheel sizes. front 195/60r15, back 195/65r15 (or viceversa)
Im in need of replacing the 2 front wheels as 1 year ago i replaced the back ones...
I originally had 185/60r15, when i replaced the back ones i bought them 195/60r15 so, a little wider but same everything else.
Right now there is a sale of x2 195/65r15 so that would make them a bit taller... can this be done? or the difference be an issue???
My gut is telling me not to mix them, but maybe there is no problem if i do this...
badillin is offline   Reply With Quote
Old 05-31-2017, 04:30 PM   #2
Not quite a true statement. Sidewall height (60) is a percentage of width so the 195 tire is taller than the 185 it replaced.
Old 05-31-2017, 04:50 PM   #3
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Staggered fitment is standard for some cars. When I met my better half, she had a Mercedes with staggered fitment. It's not cool for rotating because you can't rotate all around, but aside from that, shouldn't be an issue. Having said that, I have no experience with doing it on a Yaris, so take it for what it's worth.
On Instagram
On Wheelwell
Old 05-31-2017, 05:49 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
Your 195/60/15's (24.2") are taller than the OEM 185/60/15's (23.7"); however, they are actually a very good fitment for the Yaris.
195/65/15's (25") are very tall for the car. I wouldn't install this size. I would look for 2 more 195/60/15's.
Old 06-01-2017, 02:00 AM   #5
SirDigby
Drives: 2007 yaris 3 door
you're just fine. the only time there is an issue is on a 4x4 or AWD.
Old 06-04-2017, 08:10 PM   #6
billfires
Drives: 2010 3dr LB
Right now I am running 185/65-15 fronts and 185/60-15 rears. The first winter I owned my 2010 I ran 195/60-15 studded snows in front and the stock 185/60-15 stock tires in the rear. I had no problems running the mismatched sizes. but I am also a very restrained driver. Bill C
billfires is offline   Reply With Quote
1.5" Lower front & back: Snow issues? jmanous Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 01-28-2016 01:14 PM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 05:20 PM
Wheel Bearing Replacement (FRONT) justjesus DIY / Maintenance / Service 11 04-26-2014 08:38 PM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 01:57 PM
Yaris wheel sizes and XA (ist) wheel sizes Master General Yaris / Vitz Discussion 10 04-18-2006 12:38 PM
