Old 07-31-2017, 04:30 PM   #1
hannibal
Drives: Yaris 2012, 1.4 D4D
VSC and ABS lights on.
Diagnostics showed left front abs sensor fault, but changing it for new one did not help. Signals got thru from ABS "brain" and wiring were OK, but couldnt read the wheel locking. Inside the wheel drum we saw a lot of rust, could this be the cause? Has anyone had this kind of problem?
hannibal is offline   Reply With Quote
Old 07-31-2017, 06:18 PM   #2
B.B._07
Drives: 07 5dr
What's the condition of the ABS tone ring? If it's all rusty with deformed and missing teeth it will cause the ABS wheel speed sensor to give a faulty reading.
Old 08-01-2017, 12:12 PM   #3
texascolt45
Drives: 2015 yaris
had the exact thing happen on my 09 tacoma.changed the wheel bearing hub assembly.got both lights.changed the sensor,didnt help, traced the harness and bought the lower one.didnt help.swapped the sensor from the rear to the front,didnt help.lights clear at about 28 mph, but come back on at 62 or so.went thru some water one time and it did the same thing, but it cleared the next day.
texascolt45 is offline   Reply With Quote
Old 12-06-2017, 01:40 PM   #4
hannibal
Took some time, but all OK now.
Took it to dealership and they found broken wire somewhere between abs sensor and enginebay.
All good now, though i have some doubts about wire being broken.
what winter tires do you use ? henry33 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 60 12-09-2010 11:31 PM
2010 in Canada : ABS and VSC optional??? pierdeux New YARIS Purchase Forum 4 03-28-2010 04:23 PM
