Old 01-01-2018, 08:05 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Valve Cover Bolt Size help. please.
I was inspecting behind my engine to see if I have any visible exhaust manifold leaks and noticed I'm missing one valve cover bolt. There is a small oil leak where the bolt is missing.
Does anyone know the specs on this bolt so that I can replace it? I am still planning removing the valve cover, but will need a bolt anyway.
EDIT: The bolt appears to be part Toyota 91511-C0622, but rather than order and wait for one. I'd like to try to match locally without having to remve another one.
Thanks in advance.
Whiteline Control Arm Bushing install and Review tmontague Performance Modifications 3 06-08-2019 03:42 AM
fuel tank heatshield bolt size? antone DIY / Maintenance / Service 1 04-05-2015 04:10 AM
FS: Polished Valve Cover Daddie Y Items for Sale by private party 5 10-11-2014 04:12 AM
Transmission Drian Bolt washer size CB900F2 DIY / Maintenance / Service 14 12-07-2008 08:03 AM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 05:15 PM
