Projector headlight opinions
Are these any good?
http://www.carid.com/2008-toyota-yar...-12131502.html What about these? http://www.carid.com/2008-toyota-yar...ts-439957.html Thinking about changing out the oem's.
- The Black Ship Yaris - |
Not quite a noob
Bottom one is for Sedan.
The link in the first one, is quite common here for drop in projector headlight. Simply put, it is form over function. It looks great on the car, but the output and light quality is terrible.
Right. must have posted the wrong link
Do they put out as much light as the oems. That's my only question. I cant find the lumens info. Don't want to to do HID, and I like the way the spec-d's look.
Not quite a noob
^ yes. I had some similar before and threw HIDs in them. The light output was "better" but I didn't like the cutoff on the right being super high. Didn't want to blind drivers as I passed or drove in the left lane.
no where near as bright as OEM, or evenly lit, there will be hot spots and the cut off is weird, i had to flatten it out and still no a sharp cut off. They look amazing but perform subpar.
Do they accept different bulbs to make them brighter or are you just stuck with whats in them?
EDIT: Apparently, the bulbs can be upgraded http://www.protuninglab.com/xehidkit06to.html
You just said you dont want to do HID tho. I have HID in mine, and it does help the light to be brighter (duh) but the reflector bowl really wasnt design for it, so hotspots are even worse.
I opted for a 12" LED light bar and LED replacement bulbs. Mounted the bar using the license plate bolts.
Plenty of nice clean daylight (4500K) illumination down the road now.
- The Black Ship Yaris - Last edited by blktiger60; 03-04-2018 at 11:47 PM. Reason: update |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
Or get proper HID projectors and you wont need that nonsense
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
![]() ![]() Drives: 2009 Yaris 4DR Join Date: Aug 2017
| I NEED Boost... Opinions puh-lease | Focus_Sh1ft | Forced Induction Forum | 551 | 02-08-2013 06:55 PM |
| rim/coilover opinions | ilikerice | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 11-12-2010 08:02 PM |
| headlight opinions | whiteghetto | DIY / Maintenance / Service | 1 | 02-08-2010 07:32 PM |
| New Owner's Opinions... | guzziknight | New YARIS Purchase Forum | 18 | 06-22-2009 12:52 AM |
| Building a New Exhaust... Need some opinions. | DTM_Yaris | Performance Modifications | 21 | 12-28-2006 09:42 PM |
