![]() Drives: toyota yaris Join Date: Apr 2012
brake lights not working yaris 58 plate
My 2 lower brake lights have stopped working, the window one is still working.
Changed bulbs still nothing. Looked under dash at fuse box, on the front of the fuse box it says STOP but there is a line through this and no fuse present unless i am mistaken. Checked the fuse marked tail this one looks ok. Any ideas on what else it could be or if i have done anything wrong in tge above step. |
It should be the STOP fuse. Looking at the European EWD there isn't a configuration where the stop fuse is not used.
My mistake had another look today, it was the 1 above the STOP writing not below.
Checked fuse looked ok but i changed it anyway, still not working. |
OK. If the fuse is good and the 3rd brake light is working, then there should be power back there. If you have access to a multimeter, measure the voltage to ground at the bulb socket with the bulb removed. Also measure the resistance between the bulb socket's ground (the outer round area) and the chassis ground of the car.
Hmm, I see...
Drives: 2012 Toyota Tundra and Yaris Join Date: Oct 2016
Sorry to revive this, but man I really with there was more in this thread. Im having the same issue (tail light brake lights not working, but 3rd brake light is). I was reading some general troubleshooting and it said the actual switch on the steering column might be bad. Anyone have any knowledge on all this?
"Everything happens for a reason. Sometimes that reason is you're and idiot"
#6 | |
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
| 06-10 Yaris Sedan cold air intake $40 | kylevh21 | Items for Sale by private party | 2 | 04-01-2012 03:14 PM |
| 2012 Yaris LB Fog Lights | TimmyTwo2 | Cosmetic Modifications (Exterior/Interior) | 6 | 03-21-2012 05:54 PM |
| 2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 05:54 PM |
