Old 04-01-2018, 03:58 PM   #1
Dudejustus
Drives: 2007 Toyota Yaris Base
Power window wiring diagram
Greetings all!
So my girlfriend has a 2007 yaris hatchback and the driver side door needed to be replaced due to an accident, So i pulled one from a scrap yard and did the swap. The only problem is the replacement door has a powered window instead of manual crank. Id like to see if i could get the powered window working as i don't really feel up to swapping the window mechs.... Does anyone have a wire diagram for the power windows or know which wires are 12v, ground or go to a relay? Thank you in advance!
Dudejustus is offline   Reply With Quote
2013 Power Window already has a fuse? SecondYaris Third Gen Yaris General Discussion 0 03-06-2016 08:12 PM
Power window failure YarTrek DIY / Maintenance / Service 13 11-25-2013 01:38 AM
NEED WIRING DIAGRAM FOR FCON MINI AND AFA Faraz_Shaikh Forced Induction Forum 1 10-25-2010 01:59 PM
Power window motor BMGYaris DIY / Maintenance / Service 10 01-22-2010 10:09 PM
