Old 08-06-2007, 08:10 PM   #1
ToyotaTEch21
Drives: 2007 Yaris Sedan
Rattle TSB I found the other day.
I didn't see where this was covered yet. I know some of you guys have complained of a rattle. most common in reverse (on automatics). Well I found a TSB at work the other day for the shift cable rattling. The official fix from toyota is a zip tie . there is a bracket on the fire wall that the shift cable sits against but isn't attached to. Just zip tie the cable to the bracket, problem solved.
ToyotaTEch21 is offline   Reply With Quote
Old 09-06-2007, 06:17 PM   #2
tsportman
tsportman's Avatar
Drives: Yaris 1.8 TS
Pic asked
Anyone got a pic of the metal bracket ?
I have the same problem with my 5-speed manual Tsport !
I would like to compare the brackets and see if the tie helps me as good as with the auto transmission.
Thanks
tsportman is offline   Reply With Quote
Old 09-07-2007, 09:07 AM   #3
YarisTom73
46 and 2, just ahead...
YarisTom73's Avatar
Drives: 07 Yaris sedan
Thanks, I was looking for that one too. If possible, please post TSB number? My dealership "can't find it"
YarisTom73 is offline   Reply With Quote
Old 09-15-2007, 06:30 PM   #4
summergxz
Drives: 2006 Yaris RS Hatchback
I am experiencing exactly the same problem here with my automatic
If you could provide me some pictures that would be great
since my dealership could not fix it
I would have to do it my self i guess
Thanks
summergxz is offline   Reply With Quote
Old 09-16-2007, 02:57 AM   #5
ToyotaTEch21
Sorry guys just noticed the replies. I'll have to check on a TSB # for ya. I dont have a camera at the moment so I cant help you on a pic. But if you look behind the engine, on the drivers side you should be able to see the shift cable. Right next to it there is a bracket that is wire form. Its not solid, its just made out of thin round stock.
Old 09-19-2007, 05:20 PM   #6
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
This fix doe's indeed work... I would never have suspected that part but I secured it with a Zip-Tie and the rattle is GONE. Good find ToyotaTEch21...
I recommend doing the fix yourself from under the car. It will take you less time than driving to the dealership.
PetersRedYaris is offline   Reply With Quote
Old 11-04-2009, 07:43 AM   #7
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
Dear all, PLEASE HELP!! What is TSB and how does it look like? Does TSB related to our Auto box cable?
I'm having the rattle sound too on my auto yaris. But i can't seem to find any auto cable around my firewall. Some mentioned to cable-tie it around the cable and some mentioned to do it under the hood n etc. I'm too confused which is the exact sport to cable-tie it.
Pls provide some pictures to enlighten me. Me too want to have a "smooth" when doing reverse with my auto yaris.
evo165 is offline   Reply With Quote
Old 11-04-2009, 08:37 AM   #8
T-SB-0336-09
Rattle Noise from Automatic Transmission Control Cable
Assembly in Reverse
This was updated in September of 09 to include 08 and 09 cars.
T-SB-0336-09 Rattle Noise from AT Control Cable in Reverse.pdf
Old 11-04-2009, 10:58 AM   #9
evo165
evo165's Avatar
Thanks CTScott for the PDF file!!
I feel myself being stupid!!
Now i know TSB stand for Technical Service Bulletin after reading the pdf file!!!!!
Will find raise the veh the next time i send my veh for servicing!!!!
Old 11-11-2009, 02:10 AM   #10
birdman
Drives: '08 Blazing Blue Yaris LB
Shine a flashlight along the cable to where it passes under the rear of the engine compartment (fire wall). You will see a flimsy wire thingy. That's the bracket you zip tie the cable to. I did it from above without much trouble. If you can get access from below it's probably easier to do. Hope this helps.
birdman is offline   Reply With Quote
Old 11-11-2009, 02:44 AM   #11
YarisSedan
Drives: 08 Yaris Sedan
Oh yeah i see what you guys mean that stupid braket that seems to do nothing but allow the cable to rest against.
Old 11-11-2009, 09:54 PM   #12
severous01
mine was black sail panels right above/near side mirrors. by front windows between windshield.
remove from inside fender, do not break...install rubber o-rings. yay. i actually used some foam rings i had laying around for a cadillac door panel.
Old 03-24-2010, 09:49 PM   #13
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
I can confirm the rattle exists in 2010 US Yaris 5 door automatics
I was sitting idle...and heard...umm...a rumble ? or rattle...
anyhow....dug up this thread. ziptied my cable to the bracket. now the Yaris
is quieter in all situations. seems the rattle adds to overall noise no matter what mode
you happen to be in. ziptied....now the little piglet is quieter everywhere.
127.0.0.1 is offline   Reply With Quote
Old 03-28-2010, 01:05 AM   #14
Vang
Drives: 2008 Yaris Sedan
thanks for bumping the thread, my car is getting serviced tomorrow!
Vang is offline   Reply With Quote
Old 03-30-2010, 09:09 PM   #15
RHDVIPbB
Right beside you, wave
Drives: 08 PBM Yaris Sedan
Went in today after seeing this and they have to order the part, but it will be fixed. I take it no one had to pay for theirs. I haven't, but I did forget to ask about it.
Old 03-30-2010, 10:49 PM   #16
yarrr
Drives: 07 sedan
They have to order a zip tie? lol
yarrr is offline   Reply With Quote
Old 03-31-2010, 12:52 AM   #17
RHDVIPbB
No apparently it was something else. Hopefully a new bracket. I can't speak for other dealerships, but the tech guys at mine are very thorough. It also helps that some of them I went to school with.
Old 04-17-2010, 10:15 PM   #18
Billiam
Drives: '10 White Yaris 4D LB
Hmm...noticed that I sometimes get a similar rattle in reverse. Not everytime though. I'll have to get up under her tomorrow and check it out. I wonder if I have to use an "OEM Toyota" ziptie?
finally found the 5w-20 TSB... static808 DIY / Maintenance / Service 97 01-02-2013 07:28 AM
Toronto Canada meet June 16th second part of the day photos Ric n Sov's Vitz RS Photo-Video-Media Gallery 23 06-20-2007 02:22 PM
TSB for steering pull? vst DIY / Maintenance / Service 12 06-09-2007 03:40 PM
My New Yaris (First Car), About me, and my TSB Questions dlinkwit27 DIY / Maintenance / Service 1 06-03-2007 01:34 PM
Rattle fixed! Bretsuaz DIY / Maintenance / Service 32 03-30-2007 09:39 PM
