Brake + clutch bleeding nipples
Hi folks,
I am getting closer to the brake bleeding using a power bleeder. The brakes have been bled two years ago so I hope the nipples will not be too rusty and stiff and I will be able to loose them. But... in case I cannot... and WD40 does not help... I would like to have some spare ones in case I need to get them out some nasty way (I know that with hexagonal wrench I should not strip them but who knows). I have read a few articles and it seems that there may be actually several versions of those bleeding nipples differing in diameter, length etc... and that the only safe way to get a proper one is to screw one out, measure it and buy it then. Which is not a good advice in case I want to buy them beforehand. Is there something like "common set of bleeders" I should get in case I do not know which ones fit? I know that front and rear nipples differ. And how about the clutch slave cylinder? Is the nipple there the same as for the front or rear wheels or is it a third size? I am driving Yaris 2007 2SZ-FE 1.3 64kW hatchback 5-door. Thanks for any comment on that... :) |
Tip: Tighten the bleeder nipples a touch until you just feel them move, or hear a crack, before trying to loosen. This works well on bleeders especially because even if you break one, you know it's still tight and not going to leak. Bolts/bleeders are much stronger on tension (tightening) so they are less likely to break.
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 09:50 AM |
| Clutch Maintenance | fnkngrv | DIY / Maintenance / Service | 12 | 03-03-2017 11:42 AM |
| Aftermarket Clutch Q's | tmontague | Performance Modifications | 5 | 03-05-2016 05:33 PM |
| Front brake caliper pins | DarkSkyGhost | DIY / Maintenance / Service | 7 | 06-10-2014 09:05 AM |
| Question on brake bleeding... | Yarflana | DIY / Maintenance / Service | 6 | 04-03-2013 02:55 PM |
