Old 09-14-2018, 07:39 PM   #1
inkfromblood
Hazards / Signals Not Working
Simply put, my turn signals and hazards do not work.
(2007 liftback)
I checked all the fuses - under dash, and under hood.
And all seemed to be OK.
I pulled the flasher relay, and it looked fine so I put it back.
(unless i missed something but there wasn't much to look at)
I checked the rear signal bulbs and they looked to be seated fine.
I looked for any loose wiring or connections and couldn't find anything.
I recently JUST had the bumper replaced from being rear-ended very lightly.
(It had just snapped a couple of the tabs that hold on the bumper)
However, the past couple of days have been fine after that repair.
I was also JUST backed into by a truck, putting a decent sized dent in the panel to the rear of the drivers side door (it just missed the door and the gas cap door). However, again, its been a day since that happened and the blinkers were fine last night and this morning.
Likely going to take it into a mechanic but I figured I'd check here see if I could DIY this over the weekend.
Thanks.
inkfromblood is offline   Reply With Quote
Electronics randomly not working - NEED HELP! scoobopdan DIY / Maintenance / Service 5 12-17-2015 08:25 PM
Help! Turn Signals and Horn Stopped working kashanf DIY / Maintenance / Service 3 05-28-2014 06:20 PM
Projectors retrofit, black reflectors and dimmed front turn signals my2sense General Yaris / Vitz Discussion 11 06-20-2012 12:39 PM
Are rear red turn signals planned for Yaris as well ? 77W General Yaris / Vitz Discussion 38 02-22-2010 07:41 PM
