Old 11-25-2018, 05:11 PM   #1
nvfool
Drives: 2012 sedan
Both VSC and ABS lights on
Both lights stay on. There are no codes on the OBDII. How do I troubleshoot this?
Re-posted this in the DIY forum
nvfool is offline   Reply With Quote
Old 11-26-2018, 01:03 PM   #2
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
does your car not have these things ?
DarkShadowFox is offline   Reply With Quote
Old 11-26-2018, 04:14 PM   #3
nvfool
Drives: 2012 sedan
I'm sure it does. We have had the car for several years and the lights have only been staying on for about a year. Just now getting around to fixing it. Using the search function I found a post by CTScott? about using a jumper on the diagnostic connector and watching the lights blink. If there are codes in the system you could count the blinks. I haven't tried this yet as I thought the OBDII would read the codes.
Old 11-27-2018, 05:16 AM   #4
bobthesilent
Drives: 2011 Yaris HB
you need a dealer level tool that can diagnose ABS codes. Most normal tools cannot do that.
bobthesilent is offline   Reply With Quote
Old 11-27-2018, 04:00 PM   #5
nvfool
Drives: 2012 sedan
I hadn't thought of that. May be why CTScott suggests using jumpers and looking for the flashing lights to determine the codes. I will have to give it a try.
Old 11-29-2018, 11:06 AM   #6
stykerdk
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015
Or buy a cable with techstream on ebay.
https://www.ebay.com/sch/i.html?_fro...c&LH_PrefLoc=3
C-HR 1,8 Hybrid premium 2020
stykerdk is offline   Reply With Quote
Old 12-04-2018, 07:19 PM   #7
atomic_hoji
Drives: 2018 Yaris SE 5MT
It seems unlikely that there's a fault and no OBD2 code given that it's the ABS system; maybe if you're using a really basic scanner?
Does the car have a VSC/TRAC button on it to enable/disable? Seems like for some reason the ECM is disabling it - the lights come on to notify the driver that the systems are disabled. Because it's not a fault, no ODB2 codes are set. I would start troubleshooting with the button if you have one or something in the circuit. Loose connection at the ABS unit? I would assume a code then though..
If you do pick-up a Techstream cable just have a read up on them first - the really cheap ones sometime have compatibility issues and don't always support all functions. I've had good luck with the VXDiag cable, but it is more expensive.
Good luck with it, and let us know how you make out.
-- Adam
atomic_hoji is offline   Reply With Quote
VSC and ABS lights on. hannibal Third Gen Yaris General Discussion 3 12-06-2017 01:40 PM
what winter tires do you use ? henry33 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 60 12-09-2010 11:31 PM
2010 in Canada : ABS and VSC optional??? pierdeux New YARIS Purchase Forum 4 03-28-2010 04:23 PM
