![]() ![]() Drives: 2008 Yaris 3DR Hatch MT Join Date: Dec 2018
Grinding MT 1st gear only
Shifting down to 1st gear has just started to grind. No other gears grind up or down. Did a gear oil change with Mobil 1 75W90 about 6 months ago.
Syncro on 1st going? Clutch dragging? Shift linkage? Something else? Thanks. |
Looks like the consensus is synthetic GL-5 lube is shit for Toyota MTs. Going to try swapping it out with some GL-4 Dino.
Just make sure you go for the original Toyota 75W.
I tried Valvoline 75W90 GL4 (replacing the original oil after nearly 200tkm). It was OK but the gearbox started to grind occasionally and the shifting from 1 to 2 in cold weather (-10 Celsius) was hard. So after a year I changed it to Elf 75W80 (yes, 80 - recommended by Elf) GL4. Cold shifting problem is gone but slight grinding occurs now and then. I would say it is acceptable but next time I would definitely go for Toyota original oil. I have no problem with using non-Toyota liquids for engine oil or coolant or brakes (as long as they match the required specs) but this gearbox seems to be a real gourmet. Do not make the same mistake as I did and go for original oil directly. It costs a bit more but it is worth it! |
Mobil 1 synthetic transmission gear oil Yaris first gear grind synchro double clutch
Does this Yaris even have a first gear synchro? Very tight w/ whatever fluid was there when I got the car. Same way w/ Mobil 1 75/90. Wondered why the new Mobil 1 had a faint odor of that rank gear oil smell. Seems like a candidate for counterfeiting.
Before I had my clutch type LSD I had good luck with Amsoil MTG, it was smoother than redline MT-90 that untried before it handled the cold really well. It is a proper GL-4 iirc.
The MTG wasn't a good fluid for my LSD so I now use Redline MT-85 and no grinding issues really, and it is a great fluid for a clutch type LSD. As others stated, stick with a proper GL4 and you should be fine
Toyota Yaris manual transmission oil specification
2007 Owner's Manual for USA/Canada specifies API GL-4 or GL-5 w/ viscosity of SAE 75W-90
I bought CRC Sta-Lube GL-4 85W90 conventional (dino). Should be able to replace the Mobil 1 within the next few days.
![]() Drives: 2013 Yaris Sedan MT Join Date: Apr 2016
![]() ![]() Drives: 05 Echo Join Date: Jul 2009
I'm surprised nobody here uses Synchromesh MTF. It's a GL4 and especially good for cold temperature and fuel economy applications, and it's fixed a bad 1-2 grind for me a number of times
https://www.pennzoil.com/en_ca/produ...2NhbGU9ZW5fY2E |
#10 | |
RoyalPurple was not better, and obviously the wrong type of oil. Drove it a while, then change it to Amsoil GL4. Transmission has been better since, but I still get the occasional grind shifting into 1st while not 100% stopped. But I'm still grinding shifting from 3rd to 5th when reving high. Sent from my CLT-L04 using Tapatalk |
RP Synchromax? It's not the right oil for this transmission. It would grind shifting into 1st, and 3 4 and 5th high reving. Just go with proper oil and you shouldn't have problems.
Changed to Dino GL-4. No more grinding. Life is good.
#14 |
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015 Join Date: Mar 2012
Yaris Hybrid Limited 2015 C-HR 1,8 Hybrid premium 2020 |
#15 |
Dino GL-4 for synchromesh
Will try to replicate. Why did you opt for the Dino brand of GL-4?
re: 2-1 grind w/ the Mobil 1--was this shift also quite stiff? (Mine takes too much push to happen, but there isn't an audible grind or bite felt in the shift lever.) |
#16 |
Dino as in dinosaur (conventional, not synthetic). It was CRC Sta-Lube gear oil. Yes, on the stiff. But I had grinding on 2>1 and occasionally 2>3. Nice and smooth all around now.
#17 |
and, per your #7 post, 85w90 weight...which sould be a little thicker at low temperatures than the other oils mentioned in this thread.
| 2nd gear grinding | BoostedTRD | DIY / Maintenance / Service | 6 | 10-31-2019 09:53 PM |
| 1st gear shaking and very stiff clutch | Olea | DIY / Maintenance / Service | 9 | 03-23-2019 11:07 AM |
| problem of gearing, 1st and 2nd gear, Yaris 2008, 1.3 VVTi 64 kw | cylaptor | DIY / Maintenance / Service | 18 | 03-05-2019 11:40 AM |
| Grinding noise in 1st and reverse | spookybathtub | DIY / Maintenance / Service | 0 | 01-24-2015 09:21 PM |
| Strugeling 1st gear!!?? | mhkritzinger | DIY / Maintenance / Service | 15 | 02-06-2010 11:25 AM |
