![]() Drives: 2007 3-Door, 5-Spd Join Date: Nov 2010
Fog light install using factory wiring
A few years ago I had a post on the method that I used to install fog lights without having to go through the firewall. The Yaris' are "pre-wired" to accept aftermarket fog light kits. Here is a zip file attached that contains a doc file of the procedure.
![]() Drives: 2009 Toyota Yaris Sedan Join Date: Jun 2017
Can't believe I find it!
![]() I tried to install an after market fog lamp kit, but during the process I was more and more suspicious that my 09 yairs sedan was actually pre-wired for fog lamps. ![]() Thank you very much! |
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
I have a made in Japan Yaris for the Euro market. It's a bit more complicated with us. We have some of the wiring for the fog lamps. We already have the fog lamp relay for a rear fog lamp (an extra bright red bulb so drivers can see us) as standard. But no front lamps. The pins in the engine bay fuse box are not connected to anything on either end.
I would have to piggy back current from the switched side of the fog light relay and go through the bulkhead in order to power my front fog lamps. I have a cheap harness and the lamps from a scrapyard. I just haven't got round to doing it yet.
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
| Tags |
| aftermarket, factory wiring, fog, foglights |
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 09:47 AM |
| Fog light install | 07yaris_fe | Cosmetic Modifications (Exterior/Interior) | 10 | 07-20-2010 02:18 PM |
| Rear fog light for US '08 3Door Yaris (stick shift9 | Stefan | DIY / Maintenance / Service | 21 | 04-21-2010 05:30 PM |
| My new fog light | ezlove0710 | DIY / Maintenance / Service | 1 | 10-01-2009 05:10 PM |
| Sorry! Another fog light question. | Jrilla | DIY / Maintenance / Service | 4 | 08-23-2009 03:25 PM |
