![]() Drives: 2006 Yaris Hatch Join Date: Apr 2019
Exhaust mani removal issue
Hey, folks Im working with an 06 yaris and recently bought an ebay header as my factory manifold was cracked ive gotten every bolt out minus the 2 on the bottom of the factory manifold they are so rusted both of them rounded and with the way the pipe bends I am having a hell of a time getting them out has anyone ever had similar situation
edit have used attempted to get easy outs in but the pipe essential makes it go on an angle and i cant get a clean turn on it |
If easy out sockets dont work (use alot of pressure) then cut the bolt head and then weld a bolt onto the rest of the stud, or try vice grips on that stud when the manifold is removed
will def try that ty vm
Experienced the exact same issue with my '06. I farmed that job out. I think the guy may have unbolted the rear engine mount, removed the axles and tilted the engine forward. He did as Trevor said - welded nuts onto the studs, worked them back and forth with heat to get them out. One of my axle seals got damaged in the reinstallation process, but he came good and replaced the seal sans charge.
After much heat and removal of the axle which ill tell you the mess with that I did manage to get it out and remove the o2 sensor which seemed to be cross threaded into the stock manifold as if to prevent reuse could be crazy but i doubt its ever been off.
Now when the axle nut came about half way The impact went from full spin to wow thats spinning slow come to find the threads stripped and right near the splines you could see where it turned blue from being so hot but all and all everything goes back in tomorrow when the parts store has the new o2 thanks for all the help fellow yaris enthusiasts ! now the header is done there is more to come :D
| FS: Tanabe Medallion axle-back exhaust | Samantha0716C | Items for Sale by private party | 11 | 06-15-2018 11:16 AM |
| Please help with exhaust | 06YarisRS | DIY / Maintenance / Service | 10 | 10-03-2017 01:04 PM |
| Exhaust Manifold to Pipe Donut Gasket | yarisinpa | DIY / Maintenance / Service | 1 | 06-29-2017 04:35 AM |
| Exhaust manifold damaged by corrosion | donpalino | DIY / Maintenance / Service | 5 | 05-26-2015 05:38 PM |
| yaris voltage issue | yaris2010RS | DIY / Maintenance / Service | 11 | 12-29-2012 05:20 PM |
