![]() Drives: 08 2-Door Hatchback Yaris Join Date: Mar 2018
Issue with key not working.
I have a 2008 manual 2 door hatch. Around 3 months ago it stopped starting with the key. In order to start it I have to push start or jump the starter relay. I have replaced the Battery and starter. I have tested the clutch safety switch, alternator, starter switch, ignition switch, and relay. Also have checked all fuses. All are working. I dont have any floor mats. When pushing the clutch in the clutch safety switch activates so the bracket isnt bent. I have been searching and testing any solution I find for around 3 months. I have tried multiple mechanics and they all say its the clutch safety switch at first but then after looking over the car they cant find anything wrong. Also its not trowing any codes. If anyone has any ideas I would be really thankful.
![]() ![]() ![]() Drives: 2007 Join Date: Feb 2014
Check the ignition switch it self.
Thank you I forgot to list the ignition switch. It has been checked and is working. Im to the point now where Im just going to start replacing everything until it works.
| Key copying questions | Rob888 | General Yaris / Vitz Discussion | 1 | 04-16-2019 11:33 PM |
| Question about adding another key and fob | rcvmini | DIY / Maintenance / Service | 19 | 10-14-2018 10:17 PM |
| Electronic key not working / car not starting | jo_my_gosh | DIY / Maintenance / Service | 4 | 03-11-2014 12:15 PM |
| Issue on rostra cruise control. Stopped working!! | marcus | DIY / Maintenance / Service | 1 | 03-25-2012 05:42 PM |
| 08 HB DRL Issue | BruceLee | Cosmetic Modifications (Exterior/Interior) | 3 | 02-18-2012 11:59 PM |
