Old 06-26-2019, 06:58 AM   #1
DiabolicalBeef
Drives: 08 2-Door Hatchback Yaris
Issue with key not working.
I have a 2008 manual 2 door hatch. Around 3 months ago it stopped starting with the key. In order to start it I have to push start or jump the starter relay. I have replaced the Battery and starter. I have tested the clutch safety switch, alternator, starter switch, ignition switch, and relay. Also have checked all fuses. All are working. I dont have any floor mats. When pushing the clutch in the clutch safety switch activates so the bracket isnt bent. I have been searching and testing any solution I find for around 3 months. I have tried multiple mechanics and they all say its the clutch safety switch at first but then after looking over the car they cant find anything wrong. Also its not trowing any codes. If anyone has any ideas I would be really thankful.
DiabolicalBeef is offline   Reply With Quote
Old 06-27-2019, 08:18 AM   #2
nortonfb
Drives: 2007
Check the ignition switch it self.
nortonfb is offline   Reply With Quote
Old 06-30-2019, 05:53 AM   #3
DiabolicalBeef
Thank you I forgot to list the ignition switch. It has been checked and is working. Im to the point now where Im just going to start replacing everything until it works.
Question about adding another key and fob rcvmini DIY / Maintenance / Service 19 10-14-2018 09:17 PM
Electronic key not working / car not starting jo_my_gosh DIY / Maintenance / Service 4 03-11-2014 11:15 AM
Issue on rostra cruise control. Stopped working!! marcus DIY / Maintenance / Service 1 03-25-2012 04:42 PM
08 HB DRL Issue BruceLee Cosmetic Modifications (Exterior/Interior) 3 02-18-2012 10:59 PM
