Old 07-01-2019, 06:16 PM   #1
Pinchlite
Drives: 2007 yaris HB
hatchback drivers-passenger door plate removal?
Not sure what this thing is even called but its part of the B pillar?
I would like to remove for paint without damaging if possible.
https://i.imgur.com/Sh8b9At.jpg
Old 07-02-2019, 08:00 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Pretty sure that's either satin black paint or vinyl tape. I think it's part of the door frame, so not a removeable part, per se. Throw a painter's sheet over your car, cut out a slightly larger rectangular hole and tape off the area. Tape your door gasket rubber in the painting area. Sand with a minumum 400 paper (600 might be better), spray paint with a satin black, such as this 2K product: https://centralalbertapaintsupply.ca...d-satin-black/ or use a black spray paint and a satin clear such as: https://www.spraymax.com/en-us/produ...k-clear-satin/. I believe both of these products have UV protection built in - very important as if no UV protection is present, these will fade rapidly.
I polished mine with my DA polisher and a polishing compound and applied a few coats of Klasse SG acrylic sealant. They came out great.
Old 07-02-2019, 04:46 PM   #3
Pinchlite
I used spraymax 2K for my mirrors after UPOL color match base of course.That stuff is amazing!
I just had my car painted(3 base+ 3 clears)and know the plastic looks really weathered.I did paint the parts around the side mirrors that came off easily.Know to finish it off completly I will paint the door plate thingy.
I could mask but prefer to have the part off so I can prep it more easily and not have to mask.
Every part that I could remove including badges were removed for spray.
Old 07-02-2019, 10:49 AM   #4
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Officially, I believe it's called an 'applique'. Someone else asked about them recently and since I had mine replaced early in my car's life due to some spotting, I was familiar with them. They pop off and can be replaced or as 06 indicated, can be restored. More info including part numbers here:
http://www.yarisworld.com/forums/showthread.php?t=61884
On Instagram
On Wheelwell
Old 07-02-2019, 02:00 PM   #5
06YarisRS
Ah, I stand corrected. Great to know. Thanks!
Old 07-02-2019, 03:10 PM   #6
ern-diz
ern-diz's Avatar
The universe doesn't feel right to me thinking I corrected you on something automotive
You were and are right, though, they can be restored.
On Instagram
On Wheelwell
Old 07-02-2019, 04:40 PM   #7
Pinchlite
They Pop off.So its just a matter of pulling untill the clips give out.If it is indeed clipped,and the clips break I would think 2 sided tape would resecure it just fine.
Had an accident now passenger seatbelt and driver's airbag light won't go off Scoey DIY / Maintenance / Service 9 12-15-2022 03:29 AM
2007 Yaris Hatchback Lock Cylinder Removal Cigar_Maverick DIY / Maintenance / Service 0 10-27-2016 10:17 AM
Front passenger seat removal & SRS, seat belt issues RMcG DIY / Maintenance / Service 12 11-06-2010 12:43 AM
