![]() ![]() ![]() Drives: yaris hatch 07 640K original m Join Date: Mar 2007
radiator
I did a flush on my 1.5 radiator. It was running hot. It is only taking about half of the 5 qts
new stuff its supposed to...?? any ideas?? |
![]() ![]() ![]() Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
Well there is a drain cock on the engine as well as you have some antifreeze in your heater core.
#3 | |
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
Sent from my SM-G965F using Tapatalk
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
I didnt know about the engine drain plug. Where is it exactly on the 2007 1.5?any pics?
Because I failed to get all the coolant out I have 2 quarts of water and 2 quarts of 50/50 coolant in there. Thats only 25% of the coolant needed. At the least I will drain 2 quarts from the radiator and put in 2 quarts of 100% coolant and that should work. But I would like to drain the block.. |
| How to replace the radiator - guide | tmontague | DIY / Maintenance / Service | 10 | 02-20-2023 12:18 PM |
| !st gen pontiac vibe/toyota matrix dual core radiator install | tmontague | Performance Modifications | 5 | 05-01-2019 10:31 PM |
| Radiator Cap - 1.1 bar or 0.9? | NorthernGirl | General Yaris / Vitz Discussion | 11 | 12-29-2018 09:27 AM |
| Radiator Fan not working.. | Beubeu | DIY / Maintenance / Service | 3 | 09-21-2015 01:53 PM |
| Radiator Change | TMR3 | DIY / Maintenance / Service | 5 | 06-22-2012 01:11 PM |
