Old 11-03-2019, 06:19 PM   #1
ehud42
Drives: 2009 Yaris Sedan 5spd
Airbag - can't clear code 32 after rough passenger
2009 Yaris sedan. Canada. Airbag light on. Codes 32 & 35.
Can't clear code 32.
Backstory: Airbag light came on after a passenger w/ mental health issues had a fit of rage and was slamming themselves back into the seat repeatedly (we're working on the anger mgmt). The passenger airbag indicator says "Off" and the passenger seat belt light is flashing.
Check the codes with CTScott's procedure (http://www.yarisworld.com/forums/sho...d=1#post557473) - actually I made up a little board with 2 wires and a toggle switch so I could reliably and rapidly connect & disconnect the TC pin.
The codes are 32 & 35.
Is there a post with the codes for the 2009 Yaris? I found this - but it doesn't specify Yaris http://www.diycardoctor.com/Download...ag%20Codes.txt
But given symptoms, I went with the descriptions that match:
32: Occupant Classification System
35: Seat Position Air Bag Sensor Circuit
I then followed the clear steps hoping it was just a glitch due to the aggressive behaviour (this is when the toggle switch on a piece of wood came in super handy!).
SRS light flashes to indicate all codes cleared.
Turn car off. Disconnect. Turn car on.
SRS light on. Passenger Airbag "Off". Passenger seat belt flashing.
Now what.
Check codes and 35 is gone. But not 32. I'm still getting a 32.
I tried adjust the seat, sitting in it, seatbelt on/off. And tried resetting the codes again.
Code 32 is still there.
So, I humbly ask you fellow Yaris gurus: now what?
ehud42 is offline   Reply With Quote
Tags
airbag, passenger seat, srs
Passenger airbag recall/disable airbag? 47_MasoN_47 DIY / Maintenance / Service 20 11-06-2016 04:36 PM
Engine Control Module Code and Rough Idle rks171 DIY / Maintenance / Service 4 05-13-2015 11:47 PM
Airbag ECU code 31 - what does it really mean? ajuniper DIY / Maintenance / Service 6 11-30-2014 10:05 AM
Passenger Airbag Question RedStickHam DIY / Maintenance / Service 13 06-23-2013 05:39 PM
passenger airbag light problem (NOT stuck on) ersheff General Yaris / Vitz Discussion 3 10-12-2010 09:20 AM
