Old 04-10-2020, 07:43 PM   #1
sartor
Drives: 2008 Toyota Yaris Hatchback
HELP rear hatch latch bolts
I had to crawl into the back of my Yaris to get the rear hatch open because the pushbutton wasn't working. I noticed that the latch hook was loose. One of the bolts was spinning and the nut was lying on the inside of the sheetmetal underneath the latch hook. I removed the other nut/bolt and can't seem to figure out how to get the nut in place so I can replace the hook and get them all bolted down. HOW DO I DO THIS?? Perplexing.
Any ideas?
SOLUTION - (I'm posting a few new photos in the body of the original message because I couldn't figure out how to add images in a response to my original post)
After staring at the problem for a while I figured out a way to maneuver the nuts into place underneath the holes. There are no access holes out of view in any of the photos, only the slots in the sheet metal on the sides of the holes. So what I did was I took a 12"-or-so section of brass sheet, scribed a line in the brass the same shape as the nuts and used a jeweler's saw to cut out the holes. Then I placed the nuts into these cut-outs and maneuvered the nut under the bolt hole. Used a little loctite and drove those bolts home! The second nut was trickier because the brass sheet wanted to bump up against the first nut/bolt that I set, so I trimmed the end off of the brass so that wouldn't happen. SUCCESS!
sartor is offline   Reply With Quote
Unused plug in rear hatch door 2012 yaris slimits Photo-Video-Media Gallery 4 05-21-2016 10:09 PM
FOR SALE: 10mm Penguin Garage Hubcentric rear spacers + extended hub bolts TerenceCruz Items for Sale by private party 1 02-07-2016 06:57 PM
Wtb rear headrests for Yaris hatch Lightrfire Willing to Buy by private party 17 01-27-2016 09:54 PM
WTB: Adjustable camber bolts and rear camber shims Supra_Yaris Willing to Buy by private party 6 03-21-2015 07:16 PM
