![]() Drives: 2010 Yaris HB Join Date: Jan 2015
New fuel pump, fuel gauge showing full
I have a 2010 Toyota Yaris hatchback that won't start. The engine cranks but doesn't turn. I had a mechanic look at it and he mentioned that the fuel pump was bad.
I decided to tackle this myself to save some money. I bought the whole fuel pump assembly listed below. But the car still doesn't start. I also do not hear the fuel pump priming. Before I replaced the pump, the fuel gauge was reading empty now it reads full. If I unplug the pump, the gauge still reads full. Fuel gauge also shows full when I plug the original fuel pump assembly in. Any suggestions? https://www.rockauto.com/en/moreinfo...pR8Nc7JG51vd3b |
I pulled and replaced the fuel related fuses and now the fuel gauge shows that the the tank is empty. I put in at lease 4 gallons of gas in so I know it's not empty. I'm guessing this fuel pump assembly might not be compatible.
| 2007 sedan fuel pump not running and check engine light | nitrus10032 | DIY / Maintenance / Service | 23 | 08-23-2025 01:09 PM |
| Fuel Efficiency and the Yaris | BailOut | Fuel Economy Forum | 326 | 02-15-2025 11:09 PM |
| Could an improper seal on my fuel suction assembly be causing these issues? | ThrowingChicken | DIY / Maintenance / Service | 18 | 04-14-2018 04:44 PM |
| Fuel gauge says 1/4 but tank is empty | Shinare | DIY / Maintenance / Service | 19 | 04-09-2018 08:39 PM |
| Odd Fuel pump issue. Feeling at a loss. | Marchalis | DIY / Maintenance / Service | 4 | 03-06-2018 09:55 PM |
