Old 08-26-2020, 12:53 AM   #1
Rob888
Drives: 2010 Yaris 2 door hatchback
Serpentine belt tension questions
The spec serpentine belt deflection for my 2010 two door Yaris hatchback is .43-.51 inches according to my 2010 Yaris Hatchback Factory Repair Manual. But the manual does not specify the amount of force to apply to the belt when measuring deflection.
The standard recommended belt deflection is 1/64" per inch of belt length. My serpentine belt is 10.5" between the centers of both pulleys. So the deflection should be 10.5x1/64=.16". But again, the amount of force applied to get 1/64" deflection per inch of belt length is never specified.
I have a belt tension measuring tool that measures deflection when 10 foot pounds of force is applied. How many inches of deflection would be in the specified range for my car with ten foot pounds of force applied?
Thanks for any replies.
Rob888 is offline   Reply With Quote
Determining proper tension for new serpentine belt RMcG DIY / Maintenance / Service 11 12-30-2021 07:01 AM
Which serpentine belt? courtartanis DIY / Maintenance / Service 0 11-30-2017 11:32 AM
Squeal from Engine after replacing Water Pump and Serpentine Belt vidfan DIY / Maintenance / Service 7 06-24-2014 11:41 AM
Lost Serpentine Belt NickNickNick DIY / Maintenance / Service 33 07-31-2011 01:28 PM
serpentine belt for 2007 yaris hatchback nikki9 DIY / Maintenance / Service 4 04-09-2011 10:22 AM
