![]() Drives: Vitz 2002 1.4 Join Date: Sep 2012
Brake Failure only when pressing the pedal gently
Hi, quite recently, wife's 2002 (94000km) Yaris developed a braking issue, which i can easily replicate.
When I sharply (i.e. for immediate stop) press the brake pedal, it bites without any sponginess or other issues and car stops properly. Bite is at around 15-20% travel. When I slowly press the brake pedal or modulate it just a bit, it will start to go down until it bottoms. There is minimal to no brake force and car continues to roll. I noticed that, while bottomed the minimal brake force is only applied at the front/right wheel (perhaps because it's the closest to the master cylinder?) If I release and press back immediately, it will bite normally. - Car was fitted new brake pads/disks last year, no issues till yesterday. - New brake fluid yesterday but made absolutely no difference - No leaks, brake fluid was always full - ABS works fine Took a video, sorry for my out-of-colour socks and speaking in Greek, narration is that I slowly press the brake or modulate it a bit till it hits the floor. https://youtu.be/AL3zt1E2HiA |
![]() Drives: 2010 Yaris Sedan Join Date: Mar 2018
These are common symptoms of a failed master cylinder.
| Soggy Brake Pedal | 06YarisRS | DIY / Maintenance / Service | 3 | 07-14-2020 12:56 PM |
| Creaking noise when pressing brake pedal hard? | xdarkxfirex | DIY / Maintenance / Service | 2 | 11-06-2017 10:18 PM |
| Hiss or pfft when pressing brake pedal | kwk442 | DIY / Maintenance / Service | 3 | 06-03-2017 07:10 AM |
| red hot brake shoes | tommo | DIY / Maintenance / Service | 1 | 08-31-2011 08:34 PM |
| Brake pedal vibrates-not rotor problem | rradhay | DIY / Maintenance / Service | 9 | 11-12-2010 10:10 AM |
