Old 01-16-2011, 08:18 AM   #1
marschall
Drives: vitz 06
HOw to do Push Start D.I.Y
Hello Gentlemen sorry to bother u but i had a few questions to ask i want to install a push button on my yaris and i have a pivot push start button its relay box has four wires
1 x wire (black) for earth to attch to car body
1 X wire (red) also called terminal 15
2 x wires (blue) one called terminal 15 ign (ignition) & other terminal 50
Now i am typing the exact words on the manual
1.The green wire should be connected to terminal 15ign (ignition) behind the ignition switch,with another wire connecting Terminal 50 behind the iginition switch as well.(The power path from ign to starting motor)
2. The red wire should be connected to Terminal 15.(The power path that passes through ign)
PLz help
this is the pic i took from Memember Yarismo i hope he dont mind
marschall is offline   Reply With Quote
Old 01-16-2011, 09:27 AM   #2
The terminal 15 and 50 don't mean anything to me, but for a push-start switch to start the car, it simple needs to have the ignition in the on position and then jump the pink and black wires.
From the directions I think they are saying that the red and one blue goes to the pink and the other blue goes to the black.
Old 01-16-2011, 01:20 PM   #3
marschall
Drives: vitz 06
So wht ur saying is that the 1 blue and 1 red has to be connected 2 the pink wire?
Old 01-16-2011, 01:27 PM   #4
I believe so, based on the instructions you posted.
Old 01-17-2011, 12:28 PM   #5
marschall
Drives: vitz 06
Its aliiiiiiiiveeee!!!! thanku CT Scott
Old 01-17-2011, 01:19 PM   #6
big lo
big lo's Avatar
Drives: 2007 VIOS
That's great news, CT saves the day again, marschall post pics of the install to see how she's looking
Old 01-18-2011, 08:38 AM   #7
marschall
Drives: vitz 06
http://www.youtube.com/watch?v=XG6r69E-7uQ Problem is that the light only illuminates when i press the starter but its suppose to illuminate throughout while driving wht to do?
Old 01-18-2011, 09:29 AM   #8
Can you scan and post the wiring diagram that came with it? On Pivot's website, the wire colors that they show in their install guide are completely different (white, yellow, red and black). They mention that their are many counterfeit versions of their products, so I have a feeling that yours might be just that.
Old 01-18-2011, 09:46 AM   #9
henry33
Drives: yaris1.33
it is so simple ? just two wires and it is done ? you must be kidding, I am going to buy it asap :)
henry33 is offline   Reply With Quote
Old 01-18-2011, 10:55 AM   #10
Not to threadjack with shameless self promotion, but I developed a Push to Start inteface module that uses the OEM Toyota Push to Start Switch thanks to some interest over on the MI forum. For RHD Yaris, only the module and a Toyota PTS switch is needed. For LHD ones, a replacement trim piece is needed to neatly mount the switch (of which I imported a bunch from Europe).
Here's a video of my first test run with it:
http://www.youtube.com/watch?v=v6zinlD58Eg
Old 01-18-2011, 11:49 AM   #11
marschall
Drives: vitz 06
Actually its all in Japanese and yes i saw this video i didnt know it was you btw the instructions are in black and white and no mention of colour but i will upload the pics maybe ur right it might be a replica type of a button
Old 01-18-2011, 12:24 PM   #12
henry33
Drives: yaris1.33
scott how much does this kit cost ?
Old 01-18-2011, 12:36 PM   #13
marschall
Drives: vitz 06
will these help
File Type: jpg 1286713183430_hz-cnmyalibaba-web1_30577.jpg (52.4 KB, 552 views)
File Type: jpg nengun-2197-01-pivot-engine_starter_switch.jpg (55.0 KB, 556 views)
Old 01-18-2011, 12:43 PM   #14
That is so weird that it does not indicate colors (nor match the colors from the pivot manual).
Can the "relay box" cover be removed to reveal the mysteries within?
Old 01-18-2011, 01:02 PM   #15
marschall
Drives: vitz 06
*ahem* Sir i already have it fixed inside perhaps i could open it but dont u think it would be a bit risky
Old 01-18-2011, 01:09 PM   #16
It does look like a sealed case, so it probably wouldn't be a good idea to try to open it. Based on the wire colors and positions, as long as the red wire is connected to the pink wire on the key switch connector, the unit will receive power when the ignition switch is in the on position and the light should come on.
You might want to try emailing Pivot to see what they say.
Old 01-18-2011, 01:16 PM   #17
marschall
Drives: vitz 06
Hmm both the red and blue wire is connected 2 the pink one, perhaps if i try connecting the other blue wire to a different black wire.But thank u anyways atleast its working and shows a little light when i push it
Old 01-18-2011, 01:25 PM   #18
I think the blues are fine, as to crank the starter you need to jump power to the black wires, and having one on pink and the other on the black wires does that.
GB- Push to Start , With SMART ENTRY 1NZYaris1 Items for Sale by private party 32 12-07-2011 02:10 AM
FS: Push to Start Trim Piece CTScott Items for Sale by private party 36 05-28-2010 01:42 PM
Push Button Start Stoln Europe (continental) 20 05-24-2010 08:56 AM
push start vs electric start? yaris2010RS General Yaris / Vitz Discussion 18 04-07-2010 03:20 PM
push to start engine button DIY (done) yarismo DIY / Maintenance / Service 6 03-31-2010 05:21 PM
