Old 05-31-2018, 10:22 PM   #1
RMcG
Drives: Yaris manufactured after 2007
Determining proper tension for new serpentine belt
I recently installed a new serpentine belt. I used a Bando belt from Rock Auto that is supposed to be as good as an OEM belt. Everything went fine, but the belt started squeeling more and more shortly after installation, so I tightened the belt using a crowbar for leverage.
Since tightening the squeeling has stopped, but I am worried that the belt is too tight. People on the forum here have cautioned that if the belt is too tight, it could adversely affect bearings in the parts contacting the belt.
Is there a good way to objectively determine proper belt tension?
Thanks,
R.
RMcG is offline   Reply With Quote
Tags
belt, determining, proper, tension
Which serpentine belt? courtartanis DIY / Maintenance / Service 0 11-30-2017 11:32 AM
Yaris serpentine belt!!! Ramon1691 DIY / Maintenance / Service 9 04-11-2016 12:00 PM
Serpentine Belt Replacement - Is it possible to get it too tight? keith204 DIY / Maintenance / Service 5 05-25-2015 05:52 AM
Squeal from Engine after replacing Water Pump and Serpentine Belt vidfan DIY / Maintenance / Service 7 06-24-2014 11:41 AM
Lost Serpentine Belt NickNickNick DIY / Maintenance / Service 33 07-31-2011 01:28 PM
