Old 06-06-2007, 08:55 PM   #1
Lillydot
Absolutely Red!!!
Lillydot's Avatar
Drives: 07 A/T Yaris Liftback
I give up!
alright. i'm tired of trying to get my miles to go up. i've been driving like my grandma for the past 4 months! its sucking the life out of me! i'd rather get 25 miles per gallon, but drive the way i like! i'm a little bit above 3,000 miles, and i'm about to get an oil change. someone told me that might help. i don't know...
Lillydot is offline   Reply With Quote
Old 06-06-2007, 08:58 PM   #2
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
why change at 3000?
SPONSORED BY
Old 06-06-2007, 11:01 PM   #3
death is my gift
wacky broadway nightmare
death is my gift's Avatar
Drives: Willow is a '07 Red Yaris LB
Send a message via AIM to death is my gift Send a message via MSN to death is my gift Send a message via Yahoo to death is my gift
Originally Posted by brickhardmeat View Post
why change at 3000?
the dealer told me to change every 3000. something to do about the heat in texas and how it effects the oil as it sits in your car.
"it's always complicated and at some point someone has to draw the line and that is always going to be me. you get down on me for cutting myself off but in the end the slayer is always cut off" Buffy
death is my gift is offline   Reply With Quote
Old 06-06-2007, 09:00 PM   #4
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
do it if you got the dough!
don't give up!!!! i believe in u!!!
-- Blen
Old 06-06-2007, 09:08 PM   #5
what are you averaging? i'm averaging 39 mpg.
do you do "jack rabbit" starts? i feather the gas pedal from a stop and i don't go below 1500 rpm. i shift at 2500 rpm from first to second, and shift 150 rpms lower after that. and i drive mostly on the freeway.
Old 06-06-2007, 09:14 PM   #6
brickhardmeat
Lonesome Cowboy
i floor mine to the next red light and slam on the brakes
SPONSORED BY
Old 06-06-2007, 10:16 PM   #7
Blenjar
Blenjar's Avatar
HAHAH ME 2!!
-- Blen
Old 06-06-2007, 09:17 PM   #8
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
+1
I have always had an increase after engine break in. The only thing is all my other Yotas have been real tight (engine wise) and seemed to be really hitting there stride at about 30K.
blacksan is offline   Reply With Quote
Old 06-06-2007, 09:37 PM   #9
Vervepipes
CowCountry Hornet Handler
Vervepipes's Avatar
Drives: '08 Sedan
check to make sure none of your wheels are seized or the park break accidently on?.... if Auto that it's in OD instead of 3?...
Vervepipes is offline   Reply With Quote
Old 06-06-2007, 10:03 PM   #10
brickhardmeat
Lonesome Cowboy
ha,ha drove it off the lot with the parking brake on and for the last 4 months, that sucks
SPONSORED BY
Old 06-06-2007, 10:04 PM   #11
Lillydot
Absolutely Red!!!
Lillydot's Avatar
i'm averaging 28 miles per gallon. i do all city driving, mostly stop and start as i drive mostly during rush hour to and from work. a guy at the hyundai dealership (my botfriend just got a new car) said to change after the first 3,000 and then every 5,000 after that to help break the engine in. i haven't been doing jack rabbit starts, but i damn sure am going back to that now. i am soooo fed up with everyone darting in front of me cause i'm going so slow!
Old 06-07-2007, 10:38 AM   #12
blacksan
blacksan's Avatar
Hmmm, does this speak on the duality of this situation, or am I just reading to much in too it?
Old 06-06-2007, 10:32 PM   #13
fu_im_from_texas
fu_im_from_texas's Avatar
Drives: Liftback
Send a message via AIM to fu_im_from_texas
1) check your tire pressure - i run at 40psi for a comprimise between ride/handling/mpg
2) change your oil every 5k. toyota has put hundreds of thousands of dollars into research, and they say 5k. the us military has put hundreds of thousands of dollars into reasearch, and they say 10k ... everyone else either works for the oil industry (and wants you to buy more oil) or is guessing...
3) in dusty conditions, change your air filter...
4) http://www.yarisworld.com/forums/showthread.php?t=5979
that link has more info than you'll ever want to read...good ideas though.
fu_im_from_texas is offline   Reply With Quote
Old 06-06-2007, 11:37 PM   #14
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Send a message via MSN to jamal1984
did you calculate it right? my is sedan and i can do average of 34 to 35.
Don't drive slow it's not help at all
i do drive like a gramma b4, shift at 2500 or less and still not help,
but now i drive fast and hard most of the time, AC on all the time, shift at 3000 to 4000, carrying at least 30-50 pounds of junk all the time, and average is about 34-35mpg. i do change my oil every 3k.
jamal1984 is offline   Reply With Quote
Old 06-06-2007, 11:45 PM   #15
stuffy
stuffy's Avatar
Drives: 06 yaris 5-dr le man
this is the absolute worst kind of driving when trying to achieve good mileage, i would say 28 mpg is not terrible for city driving, especially if it is bumper to bumper rush hour traffic.
my car is used mostly around town and i average about 29 mpg in the winter but now it is up to 35 mpg since the weather warmed up.
your mileage will also improve as the engine breaks in more.
jack rabbit stars won't get you anywhere more quickly, they might be fun but they aren't going to achieve anything.
stuffy is offline   Reply With Quote
Old 06-06-2007, 11:46 PM   #16
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
Don't worry! I averaged 32-35 the 1st 4,000, since then 37-42 and have 9,300 miles now. Yes I changed my driving a bit, but not that much....42 psi in the tires,more used to the car, and I think it finally broke in, and may still be improving.
____________
Old School Cobble Jockey
churp is offline   Reply With Quote
Old 06-07-2007, 07:02 AM   #17
sambo42xa
Drives: 07 YARIS Automatic/LiftBac/Red
With me, it is exactly what churp said.....the first 4k was 32-35, and I got now 13k and get about 37-42. BUT I do not drive the city (Boston) like You do, but instead the highway (93) everyday to and from work. Also, I do not do the 42 psi thingy.
The car definatley improved with gas mileage.
sambo42xa
sambo42xa
sambo42xa is offline   Reply With Quote
Old 06-11-2007, 12:05 AM   #18
foober
Drives: two yaris liftbacks
I've always gotten around 40 miles to the gallon. Even the first days of driving. What eats up gas the most by far is quick acceleration. In any gear.
I'm actually getting above 40 miles to the gallon now after 8,000 miles. I live in the country. But I do have to do city driving when I go to town.
YOu might try this stuff. Lucas fuel treatment. Since I've been using it the last two months my car does seem to have more pep and better gas milage. http://lucasoil.hodgsoncorp.com/luca..._treatment.htm
foober is offline   Reply With Quote
DIY: Nonstop Tuning CR-Lite Pulley ChinoCharles DIY / Maintenance / Service 121 02-03-2010 05:41 AM
Next Project is >>> To give my Yaris, Wings ! Yarisagos Cosmetic Modifications (Exterior/Interior) 50 05-17-2007 07:47 PM
Joined the Army Dragonacc Off-topic / Other Cars / Everything else Discussions 27 05-15-2007 02:47 AM
ITT: We give give Re-birth to Future Mods vodkalush General Yaris / Vitz Discussion 23 04-22-2007 08:58 PM
Get your Yaris without waiting! costaricandreams New YARIS Purchase Forum 52 07-22-2006 10:42 AM
