![]() ![]() Drives: . Join Date: Mar 2019
Multiple Codes including Airbag
As follows
U0100 EMPS C1201 ABS/VSC/TRAC C1241 ABS/VSC/TRAC B1771 Occupation Detection B1801 SRS Airbag B1811 SRS Airbag It is also accompanied by an airbag light This all occurred after some front end maintenance which included lowering the crossmember and disconnecting the steering assembly. It seems to think that there is a short to the airbag squib. So somehow I've manage to disconnect or fry an ECM module. Where should I look first? I tried resetting the system by disconnecting the battery and by using an ODB2 tool and neither worked. Is this an expensive repair? I don't think it will pass inspection with the airbag light on. |
| OFFICIAL Yaris SEDAN thread | SimmZ | Photo-Video-Media Gallery | 1706 | 06-22-2025 06:33 AM |
| Multiple fault codes but no CEL | Neinris | DIY / Maintenance / Service | 28 | 03-12-2022 09:00 PM |
| Airbag - can't clear code 32 after rough passenger | ehud42 | DIY / Maintenance / Service | 1 | 11-05-2019 04:03 PM |
| DIY aftermarket steering wheel install with horn and airbag delete | tmontague | Performance Modifications | 19 | 11-30-2018 01:19 PM |
| Airbag codes | othater | DIY / Maintenance / Service | 22 | 09-03-2012 09:51 AM |
