![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
Piggyback ECU upgrade
had a basic timing advance ecu when i changed to E85..but i felt like its not enough..
instead of going for cams im giving shot to piggyback ecu with more controls..so i took them out and installed piggyback ecu..advance timing is set same as before, now controls fuel injection(1jz injectors) and fuel cut at 7,000rpm(factory 6,500rpm)..no, i cannot pass 7,000rpm without proper cams and after market valves/springs.. it feels strong and smooth through out the whole rpm band, i think fuel injections doing its job..20170211_160939.jpg20170211_135138.jpg Sent from my SM-N920C using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
Interesting... never heard of a brand called "Piggyback" - my logic when I read that is as if you were saying I drive a "Car" which in fact you do... but instead of calling it Toyota Yaris - they literally name it "Car"
![]() Can you give us more info on this "Piggyback" piggyback? Can you tell us more about this basic timing advance ECU or was the brand literally called that as well and it's just not something found in the states? Did it only advance timing and not able to retard any timing? I have tried reading about the KKT 2.0 piggyback but I don't understand the language they speak in most videos that explain what it is and what it does. Do you recall the specs on the 1JZ injectors and why you chose them over the 1ZZ that are rated at 255cc? |
#3 | ||
i chose 1jz injectors because....i dont know haha...i just did? its the most cheapest and common injectors out here in asia.. Tuning fuel injection directly by lifting the 0 + 250 (table 32X16 TPS / MAP). Tuning ignition + 80 ° C, -120 (table 32X16 TPS / MAP). Pedal Shift Timing Pedal Shift Injection Acceleration Enrichment Tuning 2 Mode operation. Coil has more time charts. Release cycle engine The O2 viewed Calibrate leg throttle Calibrate Map it Mis fire / Off Mode operation. Launch switch (the lock out) * Auto functions do not show. Anti Lag (gear around the fall). Shiftlight (position shift). Release cycle engine Tuning Vtec Close loop tuning 😇 Tuning Vvti Nitrous injected Quote:
Drives: 2015 Yaris LE 3door 1F7 Join Date: Feb 2017
How about the HKS Is?
go check the function out on hks is bro....
i think every piggy back ecu makes your engine perform 20~30% better...i bet standalone does fabolous job... Sent from my SM-N920C using Tapatalk
#6 | |
Sent from my LG-H918 using Tapatalk |
![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
You can use an AEM FiC 6 (Piggyback) and still pass inspection. Has functions for two maps. I'm in New Jersey and can pass no problem.
I'm currently running and have been for a while a Blitz supercharger ect ect.
"It hurts more when its wet" |
#10 | |
#11 | |
http://friedrice.blogspot.com.au/201...and-setup.html
http://friedrice.blogspot.com/2014/0...map-steps.html annnnd http://friedrice.blogspot.com.au/201...maf-clamp.html annnd http://friedrice.blogspot.com.au/201...92354555977057 annnd http://friedrice.blogspot.com.au/201...rting-map.html :D? am I good at finding things or what? |
Yes retains stock Ecu. Think of this as an in between the engine and the Ecu. It sends singles data back to the Ecu to assume normal conditions meanwhile useing your own map. If you tune wrong you will throw codes. If tuned right you won't. As I said before. I live in New Jersey where state inspection is mandatory anything 95 or newer.
#14 | |
#15 |
What do you mean by print out.
#16 |
#17 |
If we pass we don't get paperwork they just scrap off our old sticker and put a new one on. You are tho allowed to have 1 monitor not complete. As long as the rest are. I can use my torque app tomorrow and take a video of the monitors
#18 | |
| Need Help with 2NZ ECU pinout | Aleil | DIY / Maintenance / Service | 3 | 12-28-2020 10:40 AM |
| I finally cracked the Odometer and SRS ECU code | CTScott | DIY / Maintenance / Service | 22 | 10-27-2016 02:50 AM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 02:15 AM |
| Yaris ECU broken??!!!!!! | phb10186 | General Yaris / Vitz Discussion | 30 | 05-26-2010 10:56 AM |
| Tricking the ECU to Relearn AF map | gwasabi | Performance Modifications | 126 | 05-16-2009 07:15 PM |
