Old 03-14-2022, 09:37 PM   #1
pb2k
Drives: 07 Yaris HB
Help identifying failing part
Can anyone tell me what this part is and how serious it will be if it completely fails? It's making an awful noise that mostly goes away if I manually press the valve(?).
I also noticed that the engine occasionally won't return to idle when I take it out of gear.
Naturally I'm on a road trip in Eastern Utah, 250 miles from the nearest Toyota dealership on my route and 1100 miles from home. I don't have much choice but to try to make it to Salt Lake tomorrow, but I will have to skip Arches NP if this is critical.
pb2k is offline   Reply With Quote
Old 03-15-2022, 01:01 AM   #2
Cletus Garfunkle
Average KKT User
Cletus Garfunkle's Avatar
Drives: 2001 Echo
I'm guessing you own a manual/standard Toyota Yaris. From what this looks like it is a clutch slave cylinder or Toyota calls it a Clutch Release Cylinder in the manual. I'm not 100% sure because I own an auto 2001 Toyota echo. If it fails the clutch wont engage or disengage could make a clutch noisy, slip, chatter. It's not the biggest deal in the world but get it fixed when you can shouldn't be very hard to do urself seems like 2 bolts and disconnect clutch line. I couldnt tell you about the car not returning to idle might be a different problem.
Cletus Garfunkle is offline   Reply With Quote
Old 03-15-2022, 08:10 AM   #3
ex-x-fire
You might have a clutch throw bearing making noise.
Old 03-15-2022, 09:12 AM   #4
pb2k
Drives: 07 Yaris HB
Thanks. I found a reference to a seal kit (04313-35060) that might be the cure, but being so far from home, I think the dealership is the only option.
Old 03-17-2022, 07:20 PM   #5
pb2k
Drives: 07 Yaris HB
So I ended up deciding to head for home, as the sound almost completely went away once I was up to speed on the highway.
I pulled it apart today and the cylinder itself actually seems fine. I pulled the boot off the levered part attached to the engine and shot some WD-40 in there and tried to clean it out with some paper towel. It now makes no noise with the clutch out (huge improvement) and just a little bit of growl when the clutch is pressed in.
Is that part suppose to be lubricated at all? I don't think transmission fluid is present in that area, but the WD-40 I shot in there drained away somewhere (hopefully not into the transmission fluid). I also noticed that part was really quite loose and wobbly, but that could be by design?
I'm thinking I'll still take it into the dealership, just to have it checked over and make sure I'm not overlooking something that could bite me in the arse down the road.
Old 03-28-2022, 01:10 PM   #6
Mike Dexter
Drives: '10 Hatchback
The shift fork is the part you are talking about, and getting squeaky is a common issue. I saw a recommendation on another thread to spray lithium grease, and that worked well for me. The shift fork lives inside the bell housing, which is separated from the transmission internals, so no transmission fluid is there. I replaced by clutch last year and from what I remember the fork had a little bit of play along its axis of rotation.
Mike Dexter is offline   Reply With Quote
Old 04-12-2022, 06:05 PM   #7
pb2k
Drives: 07 Yaris HB
I tried the lithium grease last week as it started making noise again but it didn't help. I had decided to call and make an appointment today and not drive it anymore, but my mom needed it this afternoon (couldn't find her keys) and it made it ~10km before dying at a red light, literally right in front of a Toyota dealership. Lucky break there (service adviser was able to limp it in), but I have a bad feeling that my clutch is now a goner.
3rd Gen Vitz RS (and G's) Tail Lights: Part Numbers, Ordering, and Installation keiri Third Gen Yaris General Discussion 26 09-04-2020 01:01 AM
AFE Intake part - were to locate Darwin84020 Performance Modifications 1 03-26-2017 05:35 PM
Evap canister part number for 2007 yaris sedan baseballfan416 DIY / Maintenance / Service 4 04-26-2015 12:16 AM
part number for Antenna cr.chango DIY / Maintenance / Service 3 11-13-2009 03:40 PM
Buying One Specific Part.... hasher22 General Yaris / Vitz Discussion 2 08-26-2006 10:57 AM
